1kHz timer behavior on Cyclone V
    Thomas Doerfler (nt)
    Thomas.Doerfler at imd-systems.de
    Fri Dec  9 06:58:45 UTC 2016
Hi,
it's even worse: since the transfer of one character (8 bits) requires a
leading startbit and a trailing stopbit (= total of 10 bits), you can
only print 11.52 characters per 1ms.
Am 09.12.2016 um 07:48 schrieb Sebastian Huber:
> Hello Janet,
> a printk() inside an ISR is quite bad. Lets assume it uses a serial
> line with 115200 bits per second, then you can print 14.4 characters
> per 1ms.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available on request
