RTEMS Trace Tool
Tue Feb 16 23:18:47 UTC 2016
On 10/02/2016 21:11, Arwa Khannoussi wrote:
> I just started using the RTEMS trace tool, after having a look at
> https://devel.rtems.org/wiki/Developer/Projects/Open/TraceTool and
> https://code.google.com/archive/p/rtems-tracing/
> It's mentioned to contact Chris Johns for more informations, so here I am.
Sorry for the delay, I have been away for a few weeks.
> My questions are:
> - Is this tool still functional, because there is no updates since 2009?
Please take a look at https://devel.rtems.org/wiki/Developer/Tracing.
> - I'm using RTEMS 4.11 not 4.10 does that make any problem?
> - In the sources given at
> https://code.google.com/archive/p/rtems-tracing/ the file wrapper.h used
> in rtems_trace_generator.py is missing so I tried to fixe the bugs
> caused by the absence of this file but the problem is that there is not
> the sources of the two principals functions "rtems_capture_trace_record"
> and "rtems_capture_trace_log".
> My question is where could I find those two functions?
The work done in those projects provided the basis for the trace linker
tool which is part of the RTEMS Tools project. See the wiki I provided
above.
