Crash under sparc/rtems-4.11 when compiling with FPU
Wed Feb 17 09:12:30 UTC 2016
Hello,
since this issue pops up every now and then we should eventually fix it.
My approach would be to add the following BSP variants:
leon2fp (is the LEON2 still relevant?)
leon3fp
Which compiler flags should we use? We have the following multi-libs
available:
-mcpu=leon3
-mcpu=leon3v7
-mcpu=leon
-mcpu=leon -mfix-ut699
-mcpu=leon -mfix-at697f
I guess the compiler issue with respect to spurious FP instruction
generation is fixed:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=18900
However, this should be checked by manual inspection of the
librtemsbsp.a and librtemscpu.a for each new compiler version.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
