RTEMS 4.11 tools in RTEMS 4.8 hardware? GDB issues
José Pedro Canilho
jose.canilho at spinworks.pt
Wed Feb 17 16:13:59 UTC 2016
I've successfully installed RTEMS 4.11 in my development PC a few days
ago, by performing the following steps:
/ > >>> cd //
// > >>> mkdir -p development/rtems/src //
// > >>> cd development/rtems/src //
// > >>> sudo apt-get install git //
// > >>> git clone git://git.rtems.org/rtems-source-builder.git //
// > >>> cd rtems-source-builder //
// > >>> sudo apt-get install bison cvs g++ texinfo flex //
// > >>> sudo apt-get install build-essential vim zlib1g-dev
libncurses5-dev python-dev //
// > >>> source-builder/sb-check //
// > >>> cd rtems //
// > >>> ../source-builder/sb-set-builder --log=l-sparc.txt //
// > >>> --prefix=$HOME/development/rtems/4.11 4.11/rtems-sparc //
// > >>> $HOME/development/rtems/4.11/bin/sparc-rtems4.11-gcc -v //
// > >>> git clone git://git.rtems.org/rtems.git //
// > >>> export PATH=/development/rtems/4.11/bin:$PATH //
// > >>> ./bootstrap //
// > >>> cd .. //
// > >>> mkdir leon2//
// > >>> cd leon2 //
// > >>> ../rtems/configure --target=sparc-rtems4.11
--enable-rtremsbsp=leon2 --enable-tests=samples --disable-posix//
// > >>> make//
// > >>> sudo PATH=${HOME}/development/rtems/4.11/bin:${PATH} make
install/
I've then used Eclipse Helios, along with CDT, Zylin and RTEMS plugin,
to create some simple applications on my target hardware. All
aplications compiled and linked without errors. However, upon launching
the debug configuration on Eclipse, I'm noticing the following error:
/trap_table () at
../../../../../../../../rtems/c/src/lib/libbsp/sparc/leon2/../../sparc/shared/start/start.S:96//
//96 RTRAP( 0, SYM(hard_reset) ); ! 00 reset
trap//
//load//
//Loading section .text, size 0x14520 lma 0x40000000//
//Loading section .data, size 0x680 lma 0x40014520//
//Start address 0x40000000, load size 84896//
//Transfer rate: 7 KB/sec, 3858 bytes/write.//
//run//
//../../gdb-7.9/gdb/thread.c:89: internal-error: inferior_thread:
Assertion `tp' failed.//
//A problem internal to GDB has been detected,//
//further debugging may prove unreliable.
After reading some documentation, I realised that my target hardware
uses RTEMS 4.8. Can this be caused by some sort of backward incompatibility?
I would easily replicate my installation steps for 4.8, but apparently
the Git repositories don't have a 4.8 branch.
Any help is appreciated.
Thanks in advance.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160217/ee464d73/attachment.html>
