RTEMS ARMv8 Query
Raghav Nayak raghav.nayak at nxp.com
Wed Feb 24 06:58:11 UTC 2016
Hey Nick/Sebastian,
Then in that case if I need to work out for armv8 , Do you have any pointers to start with?
With Regards
  Raghav
-----Original Message-----
From: Nick Withers [mailto:nick.withers at anu.edu.au]
Sent: Wednesday, February 24, 2016 12:25 PM
To: Raghav Nayak; Sebastian Huber
Cc: users at rtems.org
Subject: Re: RTEMS ARMv8 Query
On Wed, 2016-02-24 at 06:41 +0000, Raghav Nayak wrote:
> Hi Sebastian,
> Thanks for your reply. Is there any option to bypass source builder
> and provide bare-metal ARMv8 toolchain path directly to build RTEMS
As Sebastian pointed out, RTEMS doesn't currently support the ARMv8 anyway, so this wouldn't help you.
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Wednesday, February 24, 2016 1:46 AM
> To: Raghav Nayak
> Hello,
> ARMv8 is currently not supported in the tool chain or RTEMS itself,
> since nobody asked for it up to now. If you are interested in RTEMS
> support for ARMv8, then you can add it yourself or find someone how
> does it for you.
> ----- Am 23. Feb 2016 um 6:46 schrieb Raghav Nayak raghav.nayak at nxp.c
> om:
> > Hi,
> > This is Raghav working with NXP Semiconductor. I have a query
> > regarding ARMv8
> > (aarch64) support in RTEMS Compiler. Please let me know do you
> > already provide support for ARMv8 Toolchain from source builder.
> > Kindly throw some light on it.
> > Thanks
> > With Regards
> > Raghav
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
