RTEMS ARMv8 Query
Raghav Nayak raghav.nayak at nxp.com
Wed Feb 24 19:43:55 UTC 2016
Hi Joel,
Could you please tell me the path in source-builder where I need to add support for armv8.
With Regards
  Raghav
-----Original Message-----
From: users [mailto:users-bounces at rtems.org] On Behalf Of Raghav Nayak
Sent: Thursday, February 25, 2016 12:06 AM
To: Gedare Bloom; Joel Sherrill
Cc: users at rtems.org
Subject: RE: RTEMS ARMv8 Query
Hey Gedare/Joel,
I don’t have experience with building toolchain. It would be great if you briefly explain me how to add armv8-a multilib option
With Regards
  Raghav
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Wednesday, February 24, 2016 11:53 PM
To: Raghav Nayak
Cc: Xu Ray; users at rtems.org
Subject: Re: RTEMS ARMv8 Query
Hi Raghav,
On Wed, Feb 24, 2016 at 1:20 PM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
> Hey,
> I am trying to build toolchain for armv8 getting following error
> "configure: error: GAS does not know what format to use for target aarch64-unknown-rtems4.12"
See Joel's email. To build a correct compiler toolchain for RTEMS, you have to modify binutils and gcc.
> Could anybody please help me to resolve this issue. Thanks in advance
> With Regards
>   Raghav
> Of Gedare Bloom
> Sent: Wednesday, February 24, 2016 4:55 PM
> To: Raghav Nayak
> On Wed, Feb 24, 2016 at 5:42 AM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
>> Hey Ray,
>> Thanks for the info. Do you have any documentation to build toolchain
>> for V8 through source builder?
> RTEMS Source Builder simplifies/scripts the procedures to build the toolchain using as much as possible the upstream (gcc, newlib, binutils, etc) sources. RTEMS needs some customization in the compiler to add the -rtems target. Since support has never been added for v8, there will not be any such compiler support available yet. So the first step has to look at adding that support:
> https://docs.rtems.org/doc-current/share/rtems/html/porting/index.html
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
