RTEMS ARMv8 Query
Joel Sherrill
joel at rtems.org
Wed Feb 24 20:04:35 UTC 2016
On Wed, Feb 24, 2016 at 1:43 PM, Raghav Nayak <raghav.nayak at nxp.com> wrote:
> Hi Joel,
> Could you please tell me the path in source-builder where I need to add
> support for armv8.
This is not an RSB option. It will require modification of GCC.
Looking at gcc/config.gcc, there is some code which looks like
--with-multilib-list=aprofile
MIGHT work. The file config/arm/t-rtems has the usual set of RTEMS multilib
variants.
The file config/arm/t-aprofile has another different set which includes
armv8.
Alternatively, an experiment would be to edit gcc/config.gcc and look for
arm*-*-rtems*
where it says to use t-rtems and change that to t-aprofile. That may or may
not work
either but if it works, it should change the multilib set to include armv8.
This is strictly something in gcc related to the files "t-*" in the target
specific configuration
directory. In this case, it is either adding to config/arm/t-rtems or
switching to
config/arm/t-aprofile. Building gcc by hand and experimenting is
unfortunately the
way to do this.
> With Regards
> Raghav
> -----Original Message-----
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Raghav Nayak
> Sent: Thursday, February 25, 2016 12:06 AM
> To: Gedare Bloom; Joel Sherrill
> Cc: users at rtems.org
> Subject: RE: RTEMS ARMv8 Query
> Hey Gedare/Joel,
> I don’t have experience with building toolchain. It would be great if you
> briefly explain me how to add armv8-a multilib option
> With Regards
> Raghav
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of
> Gedare Bloom
> Sent: Wednesday, February 24, 2016 11:53 PM
> To: Raghav Nayak
> Cc: Xu Ray; users at rtems.org
> Subject: Re: RTEMS ARMv8 Query
> Hi Raghav,
> On Wed, Feb 24, 2016 at 1:20 PM, Raghav Nayak <raghav.nayak at nxp.com>
> wrote:
> > Hey,
> > I am trying to build toolchain for armv8 getting following error
> > "configure: error: GAS does not know what format to use for target
> aarch64-unknown-rtems4.12"
> See Joel's email. To build a correct compiler toolchain for RTEMS, you
> have to modify binutils and gcc.
> > Could anybody please help me to resolve this issue. Thanks in advance
> > With Regards
> > Raghav
> > Of Gedare Bloom
> > Sent: Wednesday, February 24, 2016 4:55 PM
> > To: Raghav Nayak
> > On Wed, Feb 24, 2016 at 5:42 AM, Raghav Nayak <raghav.nayak at nxp.com>
> wrote:
> >> Hey Ray,
> >> Thanks for the info. Do you have any documentation to build toolchain
> >> for V8 through source builder?
> > RTEMS Source Builder simplifies/scripts the procedures to build the
> toolchain using as much as possible the upstream (gcc, newlib, binutils,
> etc) sources. RTEMS needs some customization in the compiler to add the
> -rtems target. Since support has never been added for v8, there will not be
> any such compiler support available yet. So the first step has to look at
> adding that support:
> > https://docs.rtems.org/doc-current/share/rtems/html/porting/index.html
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160224/50546bed/attachment.html>
