RSB fails for 4.10 and 4.9
Gerald Needell jerry.needell at unh.edu
Fri Feb 26 17:22:44 UTC 2016
FYI there is an error in:
config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
the last patch add "gcc" should be patch add "newlib"
Here is a corrected version:
# GCC 4.3.1., Newlib 1.16.0
%include %{_configdir}/checks.cfg
%include %{_configdir}/base.cfg
%define gcc_version    4.3.2
%define newlib_version 1.16.0
%define mpfr_version   2.4.2
%define mpc_version    0.8.2
%define gmp_version    5.0.5
%define with_threads 1
%define with_plugin  0
%define with_iconv   0
# The RTEMS 4.9 patches
%source set gcc
ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
%patch  add gcc
%{rtems_gcc_patches}/gcc-core-4.3.2-rtems4.9-20090825.diff
%source add gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-g
++-%{gcc_version}.tar.bz2
%patch  add newlib
%{rtems_newlib_patches}/newlib-1.16.0-rtems4.9-20090324.diff
# The gcc/newlib build instructions. We use 4.7 Release 1.
%include %{_configdir}/gcc-4.3-1.cfg
On Fri, 2016-02-26 at 17:13 +0000, Gerald Needell wrote:
> here is the full log for a 4.9 attempt.
> Note for 4.11 the kernel was not actually built but I don't seem to be
> able to prevent it from building for 4.9 or 4.10
> On Fri, 2016-02-26 at 10:54 -0600, Joel Sherrill wrote:
> > On Fri, Feb 26, 2016 at 10:36 AM, Gerald Needell
> > <jerry.needell at unh.edu> wrote:
> >         I have been experimenting with the RTEMS Source Builder under
> >         CENTOS7
> >         4.11 builds just fine as described on the wiki.
> >         I run into the same failure for 4.10 and 4.9
> >         ( I have gotten past the texinfo issues ...)
> >         The problem appears to be with git trying to download the
> >         rtems-kernel.
> >         Is there some extra step need for 4.10 or 4.9?
> >         Error messages:
> >         config: tools/rtems-kernel-4.10.2.cfg
> >         package: sparc-rtems4.10-kernel-4.10.2-1
> >         git: reset: git://git.rtems.org/rtems.git
> >         git: checkout: git://git.rtems.org/rtems.git => 4.10.2
> >         git: pull: git://git.rtems.org/rtems.git
> >         error: git command failed (/usr/bin/git): 1
> >         Build FAILED
> > Are you behind a firewall that blocks git?
> > Is there a log file with more detail?
> > --joel
> >         Thanks
> >         Jerry
> >         _______________________________________________
> >         users mailing list
> >         users at rtems.org
> >         http://lists.rtems.org/mailman/listinfo/users
