RSB fails for 4.10 and 4.9
Sun Feb 28 21:47:15 UTC 2016
On 28/02/2016 01:24, Needell, Jerry wrote:
> This is just a final recap of my experiences with the RTEMS Source Builder in case anyone else is having similar problems - your mileage may vary…
> all for SPARC architecture.
> 4.11 builds just fine as described on the wiki
> bare (sparc-elf) builds just fine as described on the wiki
> 4.9 needs a few modifications ( and likely 4.10 but I concentrated on 4.9 for my tests)
> As described on the wiki for 4.10 , 4.9 also needs texinfo-4.13
> also I found that I had to install expat-devel
> additional tweaks to .cfg files in config/tools:
> modify rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
> change patch add “gcc" to patch add “newlib" for newlib line
> modify rtems-kernel-4.9.6-1.cfg
> add
> %define rsb_released
> With those changes, I am able to build a working toolset and RTEMS kernels for 4.9
Are you able to make a patch for me with these changes? It would be nice
for the history in git to reflect the work you have done.
> Thanks again for the RSB - It is a wonderful tool
Great to hear.
