RTEMS ARMv8 Query
Raghav Nayak
raghav.nayak at nxp.com
Mon Feb 29 15:54:58 UTC 2016
Hi Joel,
After bootstrap if I want to add something for configure do you have any steps?
With Regards
Raghav
Sent: Monday, February 29, 2016 9:14 PM
To: Raghav Nayak
Cc: Chris Johns; Sebastian Huber; users at rtems.org
Subject: Re: RTEMS ARMv8 Query
On Mon, Feb 29, 2016 at 3:22 AM, Raghav Nayak <raghav.nayak at nxp.com<mailto:raghav.nayak at nxp.com>> wrote:
Hi,
I could build the armv8 toolchain properly but do I need to do anything else to build RTEMS other than providing the toolchain path
There is no 64-bit aarch64 port of RTEMS. One would have to be written.
In the mean time, you can run 32-bit ARMv7 code on the same CPU but not take advantage of newer instructions in 32-bit ARMv8 mode.
With Regards
Raghav
-----Original Message-----
From: users [mailto:users-bounces at rtems.org<mailto:users-bounces at rtems.org>] On Behalf Of Chris Johns
Sent: Saturday, February 27, 2016 9:12 AM
To: joel at rtems.org<mailto:joel at rtems.org>; Sebastian Huber
Cc: users at rtems.org<mailto:users at rtems.org>
On 27/02/2016 7:16 AM, Joel Sherrill wrote:
> Chris.. hopefully you have time this weekend to do some quick (for
> you) RSB work. :)
Yes, I will do this once the next gcc snapshot is made which should be in a day or so.
> + Jeff Johnston just cut a newlib snapshot which includes two things
> I wanted. So the tools in general need to bump for this.
> + I sent you the two patches for binutils. Hopefully he can use them
> to add the aarch64-rtems and x86_64-rtems targets to the RSB.
I will add this to rtems-tools.git/tools/4.12.
users mailing list
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20160229/74267d58/attachment.html>
