Participation in GSoC 2016
Jan Sommer
soja-lists at aries.uberspace.de
Mon Feb 29 20:24:21 UTC 2016
Hi,
If you take a look here: https://devel.rtems.org/wiki/GSoC/2015#StudentsSummerofCodeTrackingTable you can find the links to the reports and repositories of the previous GSoC.
Yurii Shevtsov was doing the work on the Ethernet/USB part for the pi.
Andre Marques worked on the SPI and SD-Card driver.
Cheers,
Jan
Am Tuesday 01 March 2016, 01:15:24 schrieb Deval Shah:
> It looks like there are more useful things in pipeline before raspberry pi
> cam support.
> Can anybody give me pointers/links to refer for porting ethernet support
> and SD card support?
> On Thursday 18 February 2016, soja-lists at aries.uberspace.de <
> soja-lists at aries.uberspace.de> wrote:
> > Am 2016-02-18 01:26, schrieb Joel Sherrill:
> >> On Feb 17, 2016 6:17 PM, "André Marques" <andre.lousa.marques at gmail.com>
> >> wrote:
> >> Was i2c fully delivered for the new driver framework? I don't recall
> >>> off-hand.
> >>> Yes the i2c driver for the Pi uses the new (linux-based) i2c framework.
> >> 10-bit addressing is untested because I had no compatible slave device.
> >>> A detailed report of my last GSOC can be found here:
> >>> https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card
> >>> SD card support was started but not completed last year, so it may be
> >> included on a potential Raspberry project. I can help with that if needed.
> >> Andres.. Thanks for speaking up. Can you update the project page and link
> >> to your blog?
> >> What else do you think needs find on the Pi and Pi2?
> > Last year there was a GSoC to add ethernet support for the raspberry pi
> > via rtems-libbsd, but I think it was never finished.
> > Maybe that could be started again?
> > I haven't researched it yet to know if it is feasible but I am curious if
> >> the Arduino HW libraries have a clean porting layer which could provide
> >> support for a lot of i2c devices. Is this a wikd goose chase or of
> >> potential value?
> > Sounds like an interesting idea, but isn't Arduino written in C++?
> > Best regards,
> > Jan
> >>> I very much look forward for any pointers on this.
> >>>>> I am eager to work for RTEMS organization because I believe my skill
> >>>>> set is best suited for this.
> >>>>> Thanking you,
> >>>>> Deval Shah
> >>>>> _______________________________________________
> >>>>> devel mailing list
> >>>>> devel at rtems.org
> >>>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> --André Marques
> >>> devel mailing list
> >>> devel at rtems.org
> >> devel mailing list
> >> devel at rtems.org
> > devel mailing list
> > devel at rtems.org
