Crash under sparc/rtems-4.11 when compiling with FPU
Athanasios.Tsiodras at esa.int
Mon Feb 8 08:50:14 UTC 2016
Hi Sebastian.
1. Regarding separate, FPU-based BSPs
Using separate BSP targets would clear up the issue... but note that the
documentation refers to the so called "deferred floating point context
switch" as a feature, not a bug... That is, whether a task/thread has
support for FPU-state-saving during context switches or not, is left up to
the creation flags of the thread itself - so that FPU-state-saving work
is only done when context switching from an FPU-enabled thread to another
FPU-enabled one (and not when switching to non-FPU threads).
2. Regarding compiling BSP with "-mhard-float"
I am guessing that you are suggesting I patch
"leon3/make/custom/leon3.cfg" and switch -msoft-float to -mhard-float
there (I didn't see anything FPU-related in the "configure" options). I'll
try this and report back.
European Space Agency (via HE Space)
Thanassis Tsiodras
Real-time Embedded Software Engineer
System, Software and Technology Department
ESTEC
Keplerlaan 1, PO Box 299
NL-2200 AG Noordwijk, The Netherlands
Athanasios.Tsiodras at esa.int | www.esa.int
T +31 71 565 5332
From: "Sebastian Huber" <sebastian.huber at embedded-brains.de>
To: "RTEMS List" <users at rtems.org>
Cc: software at gaisler.com
Date: 07/02/2016 07:40
Subject: Re: Crash under sparc/rtems-4.11 when compiling with FPU
Sent by: "users" <users-bounces at rtems.org>
Hello Athanasios,
it was always a miracle to me how you are supposed to use the leon2/leon3
BSPs with a FPU. If you want to use the FPU, then the BSP must be built
with the -mhard-float option, otherwise the FPU support is not enabled in
the operating system support. In addition the application configuration
must be compiled with exactly the same compiler flags as the BSP,
otherwise it will generate a corrupt configuration.
I think we need leon2fp and leon3fp BSPs, which use -mhard-float.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160208/24ddac17/attachment-0002.html>
