Crash under sparc/rtems-4.11 when compiling with FPU
Jiri Gaisler jiri at gaisler.se
Mon Feb 8 12:07:45 UTC 2016
On 08/02/16 11:46, Athanasios.Tsiodras at esa.int wrote:
> Hi Jerry.
> Thanks for the suggestion - indeed, If you look at my response to
> Jiri, you'll see that I verified that the -mhard-float is not
> necessary (objdump verified that FPU instructions are emitted by
> default, if you don't pass -msoft-float).
> I am now scripting my nightly build to do the patch explicitly, so I
> can follow the tip of 4.11 with native FPU support (our intended target).
> I didn't try the switch to v8 - since the removal of -msoft-float from
> leon3.cfg proved enough in my tests, and I am guessing the default
> leon3.cfg configuration was chosen to be -mcypress for a reason... At
> least I hope so :-)
Just remember that if the compiler emits *any* FPU instruction in the
kernel or non-FPU threads, you can get a crash. You should use objdump
on the final binary to verify that you don't have spurious FPU
instructions in the wrong place.
Jiri.
> Thanks!
> *European Space Agency (via HE Space)*
> Thanassis Tsiodras
> Real-time Embedded Software Engineer
> System, Software and Technology Department
> *ESTEC*
> Keplerlaan 1, PO Box 299
> NL-2200 AG Noordwijk, The Netherlands
> Athanasios.Tsiodras at esa.int | www.esa.int
> T +31 71 565 5332
> From:        "Needell, Jerry" <Jerry.Needell at unh.edu>
> To:        "Athanasios.Tsiodras at esa.int" <Athanasios.Tsiodras at esa.int>
> Cc:        "Needell, Jerry" <Jerry.Needell at unh.edu>, "RTEMS List"
> <users at rtems.org>
> Date:        08/02/2016 11:36
> Subject:        Re: Crash under sparc/rtems-4.11 when compiling with FPU
> sorry for the typo - I meant -mcpu v8 …
> I have used this for bsps (RTEMS 4.9) with FPU without needing the
> -mhard-float specification
> For non FPU bsps I have used -msoft-float
> both with-mcpu v8
> On Feb 8, 2016, at 5:14 AM, Needell, Jerry <_Jerry.Needell at unh.edu_
> <mailto:Jerry.Needell at unh.edu>> wrote:
> I thought it was best to use -mv8 rather tahtn -mcypress for leon3
> bsps?  Does this make any difference in your case?
> On Feb 8, 2016, at 4:50 AM, _Athanasios.Tsiodras at esa.int_
> <mailto:Athanasios.Tsiodras at esa.int>wrote:
> I verified Sebastian's suggestion - by modifying the leon3.cfg file...
>    diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
> b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    index 58f2f07..30fc3a4 100644
>    --- a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    +++ b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
>    @@ -9,7 +9,8 @@ RTEMS_CPU_MODEL=leon3
>     #  This contains the compiler options necessary to select the CPU
> model
>     #  and (hopefully) optimize for it.
>    -CPU_CFLAGS = -mcpu=cypress -msoft-float
>    +CPU_CFLAGS = -mcpu=cypress -mhard-float
> ...the generated binary of hello.exe works fine - I went a step
> further and did a test calculation, too:
>    diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
>    index d8fe450..6ee33f6 100644
>    --- a/testsuites/samples/hello/init.c
>    +++ b/testsuites/samples/hello/init.c
>    @@ -27,8 +27,13 @@ rtems_task Init(
>       rtems_task_argument ignored
>    +  int i = 0;
>    +  float a=3.14159f, b=1.0f;
>       rtems_test_begin();
>    -  printf( "Hello World\n" );
>    +  for (i=0; i<10; i++)
>    +      b*=a;
>    +  printf( "Hello World, %f\n", b );
>       rtems_test_end();
>       exit( 0 );
> ...which worked fine:
>    (gdb) tar extended-remote ... ( to grmon)
>    (gdb) c
>    Continuing.
>    *** BEGIN OF TEST HELLO WORLD ***
>    Hello World, 1.000000
>    *** END OF TEST HELLO WORLD ***
> ...and I made sure that FPU instructions are inside:
>      28:   82 80 7f ff     addcc  %g1, -1, %g1
>      2c:   12 bf ff ff     bne  28 <Init+0x28>
>      30:   91 a2 09 29     fmuls  %f8, %f9, %f8
>          b*=a;
>      34:   91 a0 19 28     fstod  %f8, %f8
> So, executive summary....  It seems that the default compilation
> settings of the Leon3 BSP forbid "real FPU" work.
> If one needs to work in native (non-emulated) FPU mode, then the
> leon3.cfg must be patched as I showed above.
> In the long run, as Sebastian indicated, a leon3fp (and a
> corresponding leon2fp, I imagine)
> should ideally be added as new BSP targets - and the FPU page
> (_https://devel.rtems.org/wiki/TBR/UserManual/Floating_Point_Support_)
> should probably
> be updated to indicate this.
> Thanks to everyone for their help,
> Thanassis.
> Thanassis Tsiodras
> ESTEC*
> NL-2200 AG Noordwijk, The Netherlands_
> __Athanasios.Tsiodras at esa.int_ <mailto:Athanasios.Tsiodras at esa.int>|
> *_MailScanner has detected a possible fraud attempt from "x-msg:"
> claiming to be_*___www.esa.int_ <x-msg://11/www.esa.int>
> T +31 71 565 5332
> From:        "Sebastian Huber" <_sebastian.huber at embedded-brains.de_
> <mailto:sebastian.huber at embedded-brains.de>>
> To:        "RTEMS List" <_users at rtems.org_ <mailto:users at rtems.org>>
> Cc:        _software at gaisler.com_ <mailto:software at gaisler.com>
> Date:        07/02/2016 07:40
> Sent by:        "users" <_users-bounces at rtems.org_
> <mailto:users-bounces at rtems.org>>
> Hello Athanasios,
> it was always a miracle to me how you are supposed to use the
> leon2/leon3 BSPs with a FPU. If you want to use the FPU, then the BSP
> must be built with the -mhard-float option, otherwise the FPU support
> is not enabled in the operating system support. In addition the
> application configuration must be compiled with exactly the same
> compiler flags as the BSP, otherwise it will generate a corrupt
> configuration.
> I think we need leon2fp and leon3fp BSPs, which use -mhard-float.
> E-Mail  : sebastian.huber at _embedded-brains.de_
> <http://embedded-brains.de/>
> users mailing list_
> __users at rtems.org_ <mailto:users at rtems.org>_
> __http://lists.rtems.org/mailman/listinfo/users_
> This message and any attachments are intended for the use of the
> addressee or addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in
> whole or in part) of its
> content is not permitted.
> If you received this message in error, please notify the sender and
> delete it from your system.
> Emails can be altered and their integrity cannot be guaranteed by the
> sender.
> Please consider the environment before printing this email.
> users mailing list_
> This message and any attachments are intended for the use of the addressee or addressees only.
> The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
> If you received this message in error, please notify the sender and delete it from your system.
> Emails can be altered and their integrity cannot be guaranteed by the sender.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160208/e164cb08/attachment-0002.html>
