RTEMS ARMv8 Query
Raghav Nayak raghav.nayak at nxp.com
Wed Feb 24 10:42:28 UTC 2016
Hey Ray,
Thanks for the info. Do you have any documentation to build toolchain for V8 through source builder?
With Regards
  Raghav
Sent: Wednesday, February 24, 2016 4:10 PM
To: Raghav Nayak
Cc: Nick Withers; Sebastian Huber; users at rtems.org
Subject: Re: RTEMS ARMv8 Query
There are some BSPs for V7. But V8 is 64bit instruction and I do not know how well it is compatible with 32Bit instruction.
I think you can start with toolchain for V8 and begin with the cpukit folder porting regarding the context switch and ISR handling.
QEMU 32 bit emulation for AArch64 may help you with initial debugging and toolchain testing.
-Ray
2016-02-24 17:58 GMT+11:00 Raghav Nayak <raghav.nayak at nxp.com<mailto:raghav.nayak at nxp.com>>:
Hey Nick/Sebastian,
Then in that case if I need to work out for armv8 , Do you have any pointers to start with?
With Regards
  Raghav
-----Original Message-----
From: Nick Withers [mailto:nick.withers at anu.edu.au<mailto:nick.withers at anu.edu.au>]
Sent: Wednesday, February 24, 2016 12:25 PM
To: Raghav Nayak; Sebastian Huber
Cc: users at rtems.org<mailto:users at rtems.org>
On Wed, 2016-02-24 at 06:41 +0000, Raghav Nayak wrote:
> Hi Sebastian,
> Thanks for your reply. Is there any option to bypass source builder
> and provide bare-metal ARMv8 toolchain path directly to build RTEMS
As Sebastian pointed out, RTEMS doesn't currently support the ARMv8 anyway, so this wouldn't help you.
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>]
> Sent: Wednesday, February 24, 2016 1:46 AM
> To: Raghav Nayak
> Hello,
> ARMv8 is currently not supported in the tool chain or RTEMS itself,
> since nobody asked for it up to now. If you are interested in RTEMS
> support for ARMv8, then you can add it yourself or find someone how
> does it for you.
> ----- Am 23. Feb 2016 um 6:46 schrieb Raghav Nayak raghav.nayak at nxp.c<mailto:raghav.nayak at nxp.c>
> om:
> > Hi,
> > This is Raghav working with NXP Semiconductor. I have a query
> > regarding ARMv8
> > (aarch64) support in RTEMS Compiler. Please let me know do you
> > already provide support for ARMv8 Toolchain from source builder.
> > Kindly throw some light on it.
> > Thanks
> > With Regards
> > Raghav
> > users mailing list
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
users mailing list
Thanks & Best Regards!
Ray, Xu
           /\__/\
        === 0  0 ===
  _____ \  ||  ||  /         __   __
  |  __ \ \_oo__oo_/#######o \ \ / /
| |__) |__ _ _   _            \ V /_   _
|  _  // _` | | | |            > <| | | |
| | \ \ (_| | |_| |_          / . \ |_| |
|_|  \_\__,_|\__, ( )        /_/ \_\__,_|
              __/ |/
             |___/
URL: <http://lists.rtems.org/pipermail/users/attachments/20160224/1495b137/attachment-0002.html>
