RSB fails for 4.10 and 4.9
Needell, Jerry Jerry.Needell at unh.edu
Sat Feb 27 13:04:07 UTC 2016
Progress:
I am now able to build 4.9 vis  the RSB
I added:
%define rsb_released
to the rtems-kernel-4.9.6-1.cfg file
and all became happy! It grabbed the .tar.bz file instead of using git and the build was able to complete.
So for 4.9 at least a few .cfg tweaks  are needed but it seems to work.
Thanks for providing the RSB.
BTW, I have also tried the “bare” build for sparc-elf is it works great!
Jerry
> On Feb 26, 2016, at 12:22 PM, Gerald Needell <jerry.needell at unh.edu> wrote:
> FYI there is an error in:
> config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
> the last patch add "gcc" should be patch add "newlib"
> Here is a corrected version:
> # GCC 4.3.1., Newlib 1.16.0
> %include %{_configdir}/checks.cfg
> %include %{_configdir}/base.cfg
> %define gcc_version    4.3.2
> %define newlib_version 1.16.0
> %define mpfr_version   2.4.2
> %define mpc_version    0.8.2
> %define gmp_version    5.0.5
> %define with_threads 1
> %define with_plugin  0
> %define with_iconv   0
> # The RTEMS 4.9 patches
> %source set gcc
> ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
> %patch  add gcc
> %{rtems_gcc_patches}/gcc-core-4.3.2-rtems4.9-20090825.diff
> %source add gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-g
> ++-%{gcc_version}.tar.bz2
> %patch  add newlib
> %{rtems_newlib_patches}/newlib-1.16.0-rtems4.9-20090324.diff
> # The gcc/newlib build instructions. We use 4.7 Release 1.
> %include %{_configdir}/gcc-4.3-1.cfg
> On Fri, 2016-02-26 at 17:13 +0000, Gerald Needell wrote:
>> here is the full log for a 4.9 attempt.
>> Note for 4.11 the kernel was not actually built but I don't seem to be
>> able to prevent it from building for 4.9 or 4.10
>> On Fri, 2016-02-26 at 10:54 -0600, Joel Sherrill wrote:
>>> On Fri, Feb 26, 2016 at 10:36 AM, Gerald Needell
>>>        I have been experimenting with the RTEMS Source Builder under
>>>        CENTOS7
>>>        4.11 builds just fine as described on the wiki.
>>>        I run into the same failure for 4.10 and 4.9
>>>        ( I have gotten past the texinfo issues ...)
>>>        The problem appears to be with git trying to download the
>>>        rtems-kernel.
>>>        Is there some extra step need for 4.10 or 4.9?
>>>        Error messages:
>>>        config: tools/rtems-kernel-4.10.2.cfg
>>>        package: sparc-rtems4.10-kernel-4.10.2-1
>>>        git: reset: git://git.rtems.org/rtems.git
>>>        git: checkout: git://git.rtems.org/rtems.git => 4.10.2
>>>        git: pull: git://git.rtems.org/rtems.git
>>>        error: git command failed (/usr/bin/git): 1
>>>        Build FAILED
>>> Are you behind a firewall that blocks git?
>>> Is there a log file with more detail?
>>> --joel
>>>        Thanks
>>>        Jerry
>>>        _______________________________________________
>>>        users mailing list
>>>        users at rtems.org
>>>        http://lists.rtems.org/mailman/listinfo/users
