users Digest, Vol 112, Issue 8
Sambeet Panigrahi sambeet161616 at gmail.com
Sun Jan 17 15:27:03 UTC 2016
Hi,
I was following the instructions from
https://devel.rtems.org/wiki/GSoC/GettingStarted
page.I have created the patch and the snapshot of modified Hello World
program.Can someone suggest to me where do I submit the proof.
On Sat, Jan 16, 2016 at 5:30 PM, <users-request at rtems.org> wrote:
> Send users mailing list submissions to
>         users at rtems.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.rtems.org/mailman/listinfo/users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         users-owner at rtems.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of users digest..."
> Today's Topics:
>    1. About "Add per-section compilation and linking support" and
>       libdl (?????? ???????)
>    2. Re: About "Add per-section compilation and linking support"
>       and libdl (Chris Johns)
> Message: 1
> Date: Fri, 15 Jan 2016 18:15:33 +0300
> From: ?????? ??????? <sergkruglov at bk.ru>
> To: <users at rtems.org>
> Subject: About "Add per-section compilation and linking support" and
>         libdl
> Message-ID: <FBE2DD8DEA214E2FBEF239A3F9F6B20A at NOK>
> Content-Type: text/plain; charset="utf-8"
> I succesfully use libdl with mips processors (R300 with small correct
> resole mips16 relocs).
> RTEMS 4.11 and 4.12
> 1. After patch rtems ?Add per-section compilation and linking support"
> image size reduce 811400 ?> 653864.
> It?s OK, but now rap file generate incorrectly and not load.
> Test program only get and print lists tasks, semaphores, messages,
> periiods.
> Without per-section compilation symbol map:
>                    size  align offset
>           .text:   2000     16 0x00000054 (84)
>          .const:    368      0 0x00000824 (2084)
>           .ctor:      0      0 0x00000994 (2452)
>           .dtor:      0      0 0x00000994 (2452)
>           .data:      0     16 0x00000994 (2452)
>            .bss:      0     16 -
>          strtab:     82      - 0x00000994 (2452)
>          symtab:     48      - 0x000009e6 (2534)
>          relocs:   1332      - 0x00000a16 (2582)
> Details: 0x00000020 (32)
> No details
> Strings: 0x00000994 (2452) size: 82
>               0 (0x000000):
>               1 (0x000001): rtems
>               2 (0x000007): _Heap_Get_information
>               3 (0x00001d): _Heap_Iterate
>               4 (0x00002b): _Protected_heap_Get_information
>               5 (0x00004b): rtems
>               6 (0x000051):
> Symbols: 0x000009e6 (2534) size: 48
>                    data section  value      name
>               0: 0x0012    .text 0x00000000 rtems
>               1: 0x0012    .text 0x00000000 _Heap_Get_information
>               2: 0x0012    .text 0x00000000 _Heap_Iterate
>               3: 0x0012    .text 0x00000000 _Protected_heap_Get_information
> With per-section compilation symbol map:
>                    size  align offset
>           .text:   2404     16 0x00000054 (84)
>          .const:    368      0 0x000009b8 (2488)
>           .ctor:      0      0 0x00000b28 (2856)
>           .dtor:      0      0 0x00000b28 (2856)
>           .data:      4     16 0x00000b28 (2856)
>            .bss:      0     16 -
>          strtab:    156      - 0x00000b2c (2860)
>          symtab:     96      - 0x00000bc8 (3016)
>          relocs:   1488      - 0x00000c28 (3112)
> No details
> Strings: 0x00000b2c (2860) size: 156
>               0 (0x000000):
>               1 (0x000001): rtems
>               2 (0x000007): rtems_object_get_name
>               3 (0x00001d): _Heap_Get_information
>               4 (0x000033): _Heap_Iterate
>               5 (0x000041): _Objects_Get_name_as_string
>               6 (0x00005d): _Protected_heap_Get_information
>               7 (0x00007d): putchar
>               8 (0x000085): BSP_output_char
>               9 (0x000095): rtems
>              10 (0x00009b):
> Symbols: 0x00000bc8 (3016) size: 96
>               1: 0x0012    .text 0x00000000 rtems_object_get_name
>               2: 0x0012    .text 0x00000000 _Heap_Get_information
>               3: 0x0012    .text 0x00000000 _Heap_Iterate
>               4: 0x0012    .text 0x00000000 _Objects_Get_name_as_string
>               5: 0x0012    .text 0x00000000 _Protected_heap_Get_information
>               6: 0x0012    .text 0x00000000 putchar
>               7: 0x0011    .data 0x00000000 BSP_output_char
> Dynamic loader say: Duplicate symbol BSP_output_char
> and stop loading.
> 2. Also after allocate .bss section it not zeroed and static uninitialized
> symbols have undefined value.
>   In standart linker bss section zeroed in startup procedure.
>   May be need memset after allocate bss section?
> Sorry for my english
> With best reagrds, Serg Kruglov
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.rtems.org/pipermail/users/attachments/20160115/51e7d060/attachment-0001.html
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> URL: <
> http://lists.rtems.org/pipermail/users/attachments/20160115/51e7d060/attachment-0001.png
> Message: 2
> Date: Sat, 16 Jan 2016 16:07:35 +1100
> From: Chris Johns <chrisj at rtems.org>
> To: ?????? ??????? <sergkruglov at bk.ru>, users at rtems.org
> Subject: Re: About "Add per-section compilation and linking support"
>         and libdl
> Message-ID: <5699D017.8090109 at rtems.org>
> Content-Type: text/plain; charset=UTF-8
> Do you have a patch for this?
> > RTEMS 4.11 and 4.12
> periiods.
> >                    size  align offset
> >            .bss:      0     16 -
> > No details
> >               0 (0x000000):
> >               1 (0x000001): rtems
> >               5 (0x00004b): rtems
> >               6 (0x000051):
> >                    size  align offset
> >            .bss:      0     16 -
> > No details
> >               0 (0x000000):
> >               1 (0x000001): rtems
> >               9 (0x000095): rtems
> >              10 (0x00009b):
> > and stop loading.
> This is strange. I suspect a bug has been triggered.
> > uninitialized symbols have undefined value.
> I suspect the bug is causing the same problem.
> Can you please raise a ticket in Trac and document the configure command
> line for RTEMS plus attach an example main for RTEMS, the app code and a
> script to build them. I can then take a closer look.
> Thanks
> Chris
> Subject: Digest Footer
> users mailing list
> users at rtems.org
> End of users Digest, Vol 112, Issue 8
URL: <http://lists.rtems.org/pipermail/users/attachments/20160117/47e6ba7f/attachment-0001.html>
