users Digest, Vol 112, Issue 8
Sun Jan 17 15:30:01 UTC 2016
E-mail it directly to me, and CC joel at rtems.org and chrisj at rtems.org
On Sun, Jan 17, 2016 at 10:27 AM, Sambeet Panigrahi
<sambeet161616 at gmail.com> wrote:
> Hi,
> I was following the instructions from
> https://devel.rtems.org/wiki/GSoC/GettingStarted
> page.I have created the patch and the snapshot of modified Hello World
> program.Can someone suggest to me where do I submit the proof.
> On Sat, Jan 16, 2016 at 5:30 PM, <users-request at rtems.org> wrote:
>> Send users mailing list submissions to
>>         users at rtems.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.rtems.org/mailman/listinfo/users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         users-owner at rtems.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of users digest..."
>> Today's Topics:
>>    1. About "Add per-section compilation and linking support" and
>>       libdl (?????? ???????)
>>    2. Re: About "Add per-section compilation and linking support"
>>       and libdl (Chris Johns)
>> Message: 1
>> Date: Fri, 15 Jan 2016 18:15:33 +0300
>> From: ?????? ??????? <sergkruglov at bk.ru>
>> To: <users at rtems.org>
>> Subject: About "Add per-section compilation and linking support" and
>>         libdl
>> Message-ID: <FBE2DD8DEA214E2FBEF239A3F9F6B20A at NOK>
>> Content-Type: text/plain; charset="utf-8"
>> I succesfully use libdl with mips processors (R300 with small correct
>> resole mips16 relocs).
>> RTEMS 4.11 and 4.12
>> 1. After patch rtems ?Add per-section compilation and linking support"
>> image size reduce 811400 ?> 653864.
>> It?s OK, but now rap file generate incorrectly and not load.
>> Test program only get and print lists tasks, semaphores, messages,
>> periiods.
>> Without per-section compilation symbol map:
>>                    size  align offset
>>           .text:   2000     16 0x00000054 (84)
>>          .const:    368      0 0x00000824 (2084)
>>           .ctor:      0      0 0x00000994 (2452)
>>           .dtor:      0      0 0x00000994 (2452)
>>           .data:      0     16 0x00000994 (2452)
>>            .bss:      0     16 -
>>          strtab:     82      - 0x00000994 (2452)
>>          symtab:     48      - 0x000009e6 (2534)
>>          relocs:   1332      - 0x00000a16 (2582)
>> Details: 0x00000020 (32)
>> No details
>> Strings: 0x00000994 (2452) size: 82
>>               0 (0x000000):
>>               1 (0x000001): rtems
>>               2 (0x000007): _Heap_Get_information
>>               3 (0x00001d): _Heap_Iterate
>>               4 (0x00002b): _Protected_heap_Get_information
>>               5 (0x00004b): rtems
>>               6 (0x000051):
>> Symbols: 0x000009e6 (2534) size: 48
>>                    data section  value      name
>>               0: 0x0012    .text 0x00000000 rtems
>>               1: 0x0012    .text 0x00000000 _Heap_Get_information
>>               2: 0x0012    .text 0x00000000 _Heap_Iterate
>>               3: 0x0012    .text 0x00000000
>> With per-section compilation symbol map:
>>                    size  align offset
>>           .text:   2404     16 0x00000054 (84)
>>          .const:    368      0 0x000009b8 (2488)
>>           .ctor:      0      0 0x00000b28 (2856)
>>           .dtor:      0      0 0x00000b28 (2856)
>>           .data:      4     16 0x00000b28 (2856)
>>            .bss:      0     16 -
>>          strtab:    156      - 0x00000b2c (2860)
>>          symtab:     96      - 0x00000bc8 (3016)
>>          relocs:   1488      - 0x00000c28 (3112)
>> No details
>> Strings: 0x00000b2c (2860) size: 156
>>               0 (0x000000):
>>               1 (0x000001): rtems
>>               2 (0x000007): rtems_object_get_name
>>               3 (0x00001d): _Heap_Get_information
>>               4 (0x000033): _Heap_Iterate
>>               5 (0x000041): _Objects_Get_name_as_string
>>               6 (0x00005d): _Protected_heap_Get_information
>>               7 (0x00007d): putchar
>>               8 (0x000085): BSP_output_char
>>               9 (0x000095): rtems
>>              10 (0x00009b):
>> Symbols: 0x00000bc8 (3016) size: 96
>>               1: 0x0012    .text 0x00000000 rtems_object_get_name
>>               2: 0x0012    .text 0x00000000 _Heap_Get_information
>>               3: 0x0012    .text 0x00000000 _Heap_Iterate
>>               4: 0x0012    .text 0x00000000 _Objects_Get_name_as_string
>>               5: 0x0012    .text 0x00000000
>>               6: 0x0012    .text 0x00000000 putchar
>>               7: 0x0011    .data 0x00000000 BSP_output_char
>> Dynamic loader say: Duplicate symbol BSP_output_char
>> and stop loading.
>> 2. Also after allocate .bss section it not zeroed and static uninitialized
>> symbols have undefined value.
>>   In standart linker bss section zeroed in startup procedure.
>>   May be need memset after allocate bss section?
>> Sorry for my english
>> With best reagrds, Serg Kruglov
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.rtems.org/pipermail/users/attachments/20160115/51e7d060/attachment-0001.html>
>> A non-text attachment was scrubbed...
>> Type: image/png
>> Desc: not available
>> URL:
>> <http://lists.rtems.org/pipermail/users/attachments/20160115/51e7d060/attachment-0001.png>
>> Message: 2
>> Date: Sat, 16 Jan 2016 16:07:35 +1100
>> From: Chris Johns <chrisj at rtems.org>
>> To: ?????? ??????? <sergkruglov at bk.ru>, users at rtems.org
>> Subject: Re: About "Add per-section compilation and linking support"
>>         and libdl
>> Message-ID: <5699D017.8090109 at rtems.org>
>> Content-Type: text/plain; charset=UTF-8
>> Do you have a patch for this?
>> > RTEMS 4.11 and 4.12
>> > periiods.
>> >                    size  align offset
>> >            .bss:      0     16 -
>> > No details
>> >               0 (0x000000):
>> >               1 (0x000001): rtems
>> >               5 (0x00004b): rtems
>> >               6 (0x000051):
>> >                    size  align offset
>> >            .bss:      0     16 -
>> > No details
>> >               0 (0x000000):
>> >               1 (0x000001): rtems
>> >               9 (0x000095): rtems
>> >              10 (0x00009b):
>> > and stop loading.
>> This is strange. I suspect a bug has been triggered.
>> > uninitialized symbols have undefined value.
>> I suspect the bug is causing the same problem.
>> Can you please raise a ticket in Trac and document the configure command
>> line for RTEMS plus attach an example main for RTEMS, the app code and a
>> script to build them. I can then take a closer look.
>> Thanks
>> Chris
>> Subject: Digest Footer
>> users mailing list
>> users at rtems.org
>> End of users Digest, Vol 112, Issue 8
> users mailing list
> users at rtems.org
