Problem running source builder
Fri Jan 22 06:30:47 UTC 2016
On 22/01/16 00:09, Simon Williams wrote:
> I am having problems building the arm tool set.  I built the tools
> successfully on January 9, so something has gone wrong in the last 12
> days!  This appears to  be the pertinent part of the log:-
> Running configure in multilib subdir thumb/cortex-m7/fpv5-d16/hard
> pwd:
> /home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/arm-rtems4.12
> mkdir thumb/cortex-m7
> mkdir thumb/cortex-m7/fpv5-d16
> mkdir thumb/cortex-m7/fpv5-d16/hard
> configure: creating cache ./config.cache
> checking build system type... x86_64-pc-linux-gnu
> checking host system type... arm-unknown-rtems4.12
> checking for --enable-version-specific-runtime-libs... yes
> checking for a BSD-compatible install... /usr/bin/install -c
> checking for gawk... gawk
> checking for arm-rtems4.12-ar...
> /home/simon.williams/rtems/4.12/arm-rtems4.12/bin/ar
Why did it pick up these Binutils?
> checking for arm-rtems4.12-lipo... arm-rtems4.12-lipo
> checking for arm-rtems4.12-nm...
> /home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/./gcc/nm
> checking for arm-rtems4.12-ranlib...
> /home/simon.williams/rtems/4.12/arm-rtems4.12/bin/ranlib
> checking for arm-rtems4.12-strip...
> /home/simon.williams/rtems/4.12/arm-rtems4.12/bin/strip
> checking whether ln -s works... yes
> checking for arm-rtems4.12-gcc...
> /home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/./gcc/xgcc
> -B/home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/./gcc/
> -nostdinc
> -B/home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/
> -isystem
> /home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/newlib/targ-include
> -isystem
> /home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/gcc-6-20160117/newlib/libc/include
> -B/home/simon.williams/rtems/4.12/arm-rtems4.12/bin/
> -B/home/simon.williams/rtems/4.12/arm-rtems4.12/lib/ -isystem
> /home/simon.williams/rtems/4.12/arm-rtems4.12/include -isystem
> /home/simon.williams/rtems/4.12/arm-rtems4.12/sys-include  -mthumb
> -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard
> configure: error: in
> `/home/simon.williams/rtems/rtems-source-builder/rtems/build/arm-rtems4.12-gcc-6-20160117-newlib-2.3.0.20160104-x86_64-linux-gnu-1/build/arm-rtems4.12/thumb/cortex-m7/fpv5-d16/hard/libgcc':
> configure: error: cannot compute suffix of object files: cannot compile
> See `config.log' for more details.
> make[1]: *** [configure-target-libgcc] Error 1
> The build system in Fedora Linux 23 X86_64 and is up to date.  My copy
> of the RSB repository os up to date as of tonight.
> Any ideas?
Your Binutils version is too old. The RSB has the right version, but the
configure finds something else.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
