Eclipse Pluguin Problems
Dario Baliña
dariosb at gmail.com
Thu Jan 28 13:49:58 UTC 2016
Hi all
I have successfully installed RTEMS Toolchain using the RSB and compiled
and tested some demos from exmples-v2 package in two bsp´s: sparc-sis and
arm-lpc1768.
Now I am trying to get running RTEMs Plugin for Eclipse (Galileo) on an
Ubuntu 14.04.3 machine.
RTEMS pluging configuration is:
Base path: /opt/rtems-4.12
BSP path: /opt/rtems-4.12/sparc-rtems4.11/sis
I also have tried with the BSP path like the new standard, as is remarked
in the pluguin installation guide (
https://devel.rtems.org/wiki/Developer/Eclipse/Plugin):
/home/dario/development/rtems/4.11-sparc/sis/sparc-rtems4.11/c/sis/make/
BSP Path always is were Makefile.inc is located.
The trouble comes after proyect creation, problems window shows this
errors/warnings log:
Errors:
make output parse error: java.io.IOException: No such file or directory
hello tool discovery Problem
make: *** [src/hello.o] Error 127 hello line 0 C/C++ Problem
Warnings:
Error launching external scanner info generator (/opt/rtems-4.12/bin/gcc
-E -P -v -dD
/home/dario/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.c)
hello Unknown C/C++ Problem
-E -P -v -dD
-E -P -v -dD
-E -P -v -dD
-E -P -v -dD
-E -P -v -dD
-E -P -v -dD
This is my first time installing RTEMS Toolchain, sorry if this is a
trivial question.
I couldn´t find this error in mailing list.
can I get some help on this?
thank you in advance
*DB.-*
<http://www.delsatgroup.com/>
[image: View my profile on LinkedIn]
<https://www.linkedin.com/in/dariobalina>
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/02d4665b/attachment.html>
