Eclipse Pluguin Problems
groups at chichak.ca groups at chichak.ca
Thu Jan 28 15:07:18 UTC 2016
I’d expect that the problem may be Eclipse Galileo, that came out in 2009.
Andrei
> On 2016-January-28, at 08:01, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 28/01/16 14:49, Dario Baliña wrote:
>> Hi all
>> I have successfully installed RTEMS Toolchain using the RSB and compiled and tested some demos from exmples-v2 package in two bsp´s: sparc-sis and arm-lpc1768.
>> Now I am trying to get running RTEMs Plugin for Eclipse (Galileo) on an Ubuntu 14.04.3 machine.
>> RTEMS pluging configuration is:
>> Base path: /opt/rtems-4.12
>> BSP path: /opt/rtems-4.12/sparc-rtems4.11/sis
> Did you mix 4.11 and 4.12 somehow?
