Eclipse Pluguin Problems
Dario Baliña
dariosb at gmail.com
Thu Jan 28 15:58:33 UTC 2016
I have cloned the master, not 4.11 branch, sorry.
I´m going to rebuild pointing to 4.11 branch and try again.
The with message /opt/rtems-4.12/bin/gcc, is because first parsing error I
guess.
Like this topic
https://lists.rtems.org/pipermail/users/2015-May/028800.html
Eclipse C/C++ build settings are using gcc, but because Makefile.inc of the
selected bsp is not parsed by the pluguin.
*DB.-*
<http://www.delsatgroup.com/>
[image: View my profile on LinkedIn]
<https://www.linkedin.com/in/dariobalina>
2016-01-28 12:35 GMT-03:00 Gedare Bloom <gedare at rtems.org>:
> Even though the 4.12 directory was created, it sounds like you have only
> made 4.11 toolset? You should be certain that you are on the 4.11 branches
> of all git repos (rtems-source-builder, rtems.git).
> the message with /opt/rtems-4.12/bin/gcc seems a bit strange. We don't
> usually see plain gcc installed into a location where RTEMS tools and OS
> libs are installed.
> Gedare
> On Thu, Jan 28, 2016 at 10:18 AM, Dario Baliña <dariosb at gmail.com> wrote:
>> Thanks for answering
>> If i did it, not was my intention.
>> I have cloned rtems repo from https://github.com/RTEMS/rtems.git, into
>> directory
>> /home/dario/development/rtems/src/rtems
>> After bootstrapping, I have configured target and bsp like this:
>> $ mkdir /development/rtems/4.11-sparc/sis
>> $ cd /development/rtems/4.11-sparc/sis
>> $ ../../src/rtems/configure –-target=sparc-rtems4.11
>> –-enable-rtemsbsp=sis --enable-tests=samples –-disable-posix
>> I have not specified instalation point with --prefix option, and the
>> /opt/rtems-4.12 directory was created automatically.
>> Thanks
>> *DB.-*
>> 2016-01-28 12:01 GMT-03:00 Sebastian Huber <
>> sebastian.huber at embedded-brains.de>:
>>> On 28/01/16 14:49, Dario Baliña wrote:
>>>> Hi all
>>>> I have successfully installed RTEMS Toolchain using the RSB and
>>>> compiled and tested some demos from exmples-v2 package in two bsp´s:
>>>> sparc-sis and arm-lpc1768.
>>>> Now I am trying to get running RTEMs Plugin for Eclipse (Galileo) on an
>>>> Ubuntu 14.04.3 machine.
>>>> RTEMS pluging configuration is:
>>>> Base path: /opt/rtems-4.12
>>>> BSP path: /opt/rtems-4.12/sparc-rtems4.11/sis
>>> Did you mix 4.11 and 4.12 somehow?
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160128/6fc23049/attachment-0001.html>
