Eclipse Pluguin Problems
Simon Williams
williamssimonp at gmail.com
Fri Jan 29 17:49:28 UTC 2016
You don't need to fall back to Galileo, I am running Mars on Fedora 23 with
no problems. The plugin doesn't seem to care! :-)
On Fri, 29 Jan 2016, 17:17 Dario Baliña <dariosb at gmail.com> wrote:
> I have recently built a new development environment using an Centos 6.3
> machine instead Ubuntu 14.3 and the problem was solved.
> Obviously Ubuntu 14.3 and Eclipse Galileo are not working properly.
> I´m starting to get running gdb - eclipse integration, any advice or
> supporting documentation is welcome.
> thanks in advance.
> *DB.-*
> <http://www.delsatgroup.com/>
> [image: View my profile on LinkedIn]
> <https://www.linkedin.com/in/dariobalina>
> 2016-01-28 12:33 GMT-03:00 Dario Baliña <dariosb at gmail.com>:
>> I have chosen Galileo because is recommended in plugin installation guide
>> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin as the running
>> version:
>> The current plug-in version works with the Galileo release of Eclipse and
>> CDT version 6.
>> I have one more thing trying to help to clarify.
>> When Ecplise starts, on the top of the workspace selection window, this
>> notification appear:
>> GCJ has been detected as the current Java virtual machine. Use of GCJ is
>> untested and unsupported. Please consult the documentation for more
>> Can there be any compatibility issue between Galileo and Ubuntu 14.3?
>> Can you recomend another version of Eclipse to test?
>> Thanks again
>> *DB.-*
>> 2016-01-28 12:12 GMT-03:00 Sebastian Huber <
>> sebastian.huber at embedded-brains.de>:
>>> On 28/01/16 16:07, groups at chichak.ca wrote:
>>>> I’d expect that the problem may be Eclipse Galileo, that came out in
>>>> 2009.
>>> The plug-in is likely broken on newer Eclipse versions. I think I wrote
>>> the plug-in with the Galileo version.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160129/3556fec0/attachment.html>
