rule for OBJS in 4.10.99 build method
Sat Jan 30 13:16:01 UTC 2016
I don't know what your application looks like, but you might like to
try using waf which can give you a bit more control/customization over
your build. I couldn't tell you what happens in the middle of the make
process.
Depending on how far back you are from the 4.11 release, you might
want to consider switching to it.
Gedare
On Fri, Jan 29, 2016 at 8:05 PM, Chan Kim <ckim at etri.re.kr> wrote:
> Hi,
> I'm looking for the rule to build OBJS in the build tree but I can't find it..
> we are using 4.10.99, set RTEMS_MAKEFILE_PATH appropriately,
> As you all know, the Makefile for an application has these three lines
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> include $(RTEMS_CUSTOM)
> include $(PROJECT_ROOT)/make/leaf.cfg
> I've followed all the included file (default.cfg, our_bps.cfg, target.cfg, host.cfg, main.cfg, bsp.cfg) but couldnt' find the rule for OBJS.
> Where is it defined? (I'm trying to build the application with the source located in ../src  instead of where I build it)
> Best regards,
> Chan Kim
> users mailing list
> users at rtems.org
