rtems libbsd gethostbyname did not work
Mon Jul 4 05:56:32 UTC 2016
On 30/06/16 15:42, 葡萄 wrote:
> hi,I port a usb driver form freebsd for 4G dongle, it work ,but I
> cannot use gethostbyname ,I add some code for debug,find in
> freebsd/lib/libc/net/gethostnamadr.c line 581  _nsdispatch  return
> failure, in function _nsdispatch ,
> if (isthreaded) {
> result = _pthread_rwlock_rdlock(&nss_lock);
> if (result != 0) {
> printf("nsdispatch pthread rd lock failure %d!\n",result);
> result = NS_UNAVAIL;
> goto fin;
> _pthread_rwlock_rdlock  return invalid, can you give me some advise?
> how can i let gethostbyname work?
> below is shell print for application information
Check your application configuration, you probably didn't build with
POSIX enabled or didn't configure enough rwlocks. Use the
"default-init.h" of the libbsd as an example.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
