rtems libbsd gethostbyname did not work
Mon Jul 4 06:16:43 UTC 2016
On 04/07/16 08:06, Chris Johns wrote:
>> Use the "default-init.h" of the libbsd as an example.
> Should LibBSD check the value before starting and print a warning if
> too low? I am sure lots of people will have this issue.
Yes, we had some e-mails due to a lack of resources in the
configuration. Knowing the value is the hard thing. Not everyone wants
to use unlimited objects or needs components that require rwlocks. I
would rather make the POSIX objects self-contained to get rid of the
root cause of this problem or provide better diagnostics.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
