Re: rtems libbsd gethostbyname did not work
yao0718
29171383 at qq.com
Mon Jul 4 16:12:51 UTC 2016
sure, I configure the CONFIGURE_MAXIMUM_POSIX_RWLOCKS and now it's work fine, thanks for your help
------------------ 原始邮件 ------------------
发件人: "Sebastian Huber";<sebastian.huber at embedded-brains.de>;
发送时间: 2016年7月4日(星期一) 中午1:56
收件人: "yao0718"<29171383 at qq.com>; "users"<users at rtems.org>;
主题: Re: rtems libbsd gethostbyname did not work
On 30/06/16 15:42, 葡萄 wrote:
> hi,I port a usb driver form freebsd for 4G dongle, it work ,but I
> cannot use gethostbyname ,I add some code for debug,find in
> freebsd/lib/libc/net/gethostnamadr.c line 581 _nsdispatch return
> failure, in function _nsdispatch ,
> if (isthreaded) {
> result = _pthread_rwlock_rdlock(&nss_lock);
> if (result != 0) {
> printf("nsdispatch pthread rd lock failure %d!\n",result);
> result = NS_UNAVAIL;
> goto fin;
> _pthread_rwlock_rdlock return invalid, can you give me some advise?
> how can i let gethostbyname work?
> below is shell print for application information
Check your application configuration, you probably didn't build with
POSIX enabled or didn't configure enough rwlocks. Use the
"default-init.h" of the libbsd as an example.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20160705/1b684750/attachment.html>
