Name of a BSP
Ruhollah Majdoddin
r.majdodin at gmail.com
Tue Jul 5 09:52:58 UTC 2016
It is not documented what the "name" of a (Board Support Package) BSP is.
For example, trying to configure RTEMS for Atmel SAM family, I had to
provide the BSP name to the --enable-rtemsbsp option.
As The source of BSP is in directory
c/src/lib/libbsp/arm/atsam
I assumed that the name is "atsam", which did not work. After lots of
trying, accidentally I found the file
c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
and guessed that the the name should be "atsamv", which worked.
URL: <http://lists.rtems.org/pipermail/users/attachments/20160705/a592dbd7/attachment.html>
