Name of a BSP
Tue Jul 5 10:28:18 UTC 2016
On 5/07/2016 7:52 PM, Ruhollah Majdoddin wrote:
> It is not documented what the "name" of a (Board Support Package) BSP is.
> For example, trying to configure RTEMS for Atmel SAM family, I had to
> provide the BSP name to the --enable-rtemsbsp option.
> As The source of BSP is in directory
> c/src/lib/libbsp/arm/atsam
> I assumed that the name is "atsam", which did not work. After lots of
> trying,  accidentally I found the file
> c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> and guessed that the the name should be "atsamv", which worked.
Try running 'rtems-bsp' in the top of the source tree. It will list all
the BSP in the source tree.
