Name of a BSP
Michael Westfall
mwestfal at gemini.edu
Tue Jul 5 15:02:40 UTC 2016
Remove the '5' after the ' -depth' in the 'find' command, then it works.
On Tue, Jul 5, 2016 at 10:42 AM, Joel Sherrill <joel at rtems.org> wrote:
> FYI rtems-bsps is still broken. I know we have discussed this
> before but I don't remember how to fix the find statement.
> Also it says 4.11. :)
> [joel at localhost rtems]$ ./rtems-bsps
> find: paths must precede expression: 5
> Usage: find [-H] [-L] [-P] [-Olevel] [-D
> help|tree|search|stat|rates|opt|exec] [path...] [expression]
> RTEMS 4.11
> Architectures: 0
> BSP Count: 0
> On Tue, Jul 5, 2016 at 5:28 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 5/07/2016 7:52 PM, Ruhollah Majdoddin wrote:
>> > It is not documented what the "name" of a (Board Support Package) BSP
>> is.
>> > For example, trying to configure RTEMS for Atmel SAM family, I had to
>> > provide the BSP name to the --enable-rtemsbsp option.
>> > As The source of BSP is in directory
>> > c/src/lib/libbsp/arm/atsam
>> > I assumed that the name is "atsam", which did not work. After lots of
>> > trying, accidentally I found the file
>> > c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
>> > and guessed that the the name should be "atsamv", which worked.
>> Try running 'rtems-bsp' in the top of the source tree. It will list all
>> the BSP in the source tree.
>> Chris
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
Mike Westfall
Control Systems Software Engineer
URL: <http://lists.rtems.org/pipermail/users/attachments/20160705/e19b4b69/attachment.html>
