Name of a BSP
Joel Sherrill
joel at rtems.org
Tue Jul 5 15:44:03 UTC 2016
Thanks. Pushed a fix for that and changed the version number to 4.12.
--joel
On Tue, Jul 5, 2016 at 10:02 AM, Michael Westfall <mwestfal at gemini.edu>
wrote:
> Remove the '5' after the ' -depth' in the 'find' command, then it works.
> On Tue, Jul 5, 2016 at 10:42 AM, Joel Sherrill <joel at rtems.org> wrote:
>> FYI rtems-bsps is still broken. I know we have discussed this
>> before but I don't remember how to fix the find statement.
>> Also it says 4.11. :)
>> [joel at localhost rtems]$ ./rtems-bsps
>> find: paths must precede expression: 5
>> Usage: find [-H] [-L] [-P] [-Olevel] [-D
>> help|tree|search|stat|rates|opt|exec] [path...] [expression]
>> RTEMS 4.11
>> Architectures: 0
>> BSP Count: 0
>> On Tue, Jul 5, 2016 at 5:28 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 5/07/2016 7:52 PM, Ruhollah Majdoddin wrote:
>>> > It is not documented what the "name" of a (Board Support Package) BSP
>>> is.
>>> > For example, trying to configure RTEMS for Atmel SAM family, I had to
>>> > provide the BSP name to the --enable-rtemsbsp option.
>>> > As The source of BSP is in directory
>>> > c/src/lib/libbsp/arm/atsam
>>> > I assumed that the name is "atsam", which did not work. After lots of
>>> > trying, accidentally I found the file
>>> > c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
>>> > and guessed that the the name should be "atsamv", which worked.
>>> Try running 'rtems-bsp' in the top of the source tree. It will list all
>>> the BSP in the source tree.
>>> Chris
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>> users mailing list
>> users at rtems.org
> Mike Westfall
> Control Systems Software Engineer
URL: <http://lists.rtems.org/pipermail/users/attachments/20160705/4b91f238/attachment.html>
