Name of a BSP
Wed Jul 6 01:02:54 UTC 2016
On 06/07/2016 10:55, Joel Sherrill wrote:
> On Jul 5, 2016 7:43 PM, "Chris Johns" <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>  > On 06/07/2016 01:44, Joel Sherrill wrote:
>  >> Thanks. Pushed a fix for that and changed the version number to 4.12.
> There were two patches.
I just did a pull and can only see 1 and the 5 is still present.
>  > I only saw the version change in the patch...
>  > https://lists.rtems.org/pipermail/vc/2016-July/010825.html
>  > Also I think the 5 is needed so '-depth -maxdepth 5' is needed for
> GNU find. BSD documents '-depth n'. I need to test on 4 different hosts
> to know.
> The syntax can be fixed again. At least it works at all now. :)
You get false BSPs in the list, eg
  bbxm    c/src/lib/libbsp/arm/beagle/simscripts/bbxm.cfg
