Building NetSNMP for ARM/atsamv
Joel Sherrill
joel at rtems.org
Fri Jul 8 07:51:12 UTC 2016
On Jul 8, 2016 9:44 AM, "Sebastian Huber" <
> On 08/07/16 08:54, Ruhollah Majdoddin wrote:
>> I try to have RSB to build the NetSNMP package, but it fails. The RSB
>> and RTEMS kernel are both 4.12, target architecture is ARM and BSP is
>> atsamv (arch/bsp are already built in prefix).
>> As far as I can see, one problem is that function "isspace" from
>> cctype is undeclared, and the other is with linking:
Sebastian explained the link error.
My thought on isspace is that it is guarded by a feature flag which you
haven't enabled. See http://linux.die.net/man/3/isspace for advice. That
may indicate an issue with the single file or an argument to pass to define
the flag.
>> linkcmds.base:390 cannot move location counter backwards (from
>> 00000000204bf480 to 000000002045f000)
>> Any suggestions?
> Your application exceeds the available memory resources. See README of
the BSP for memory options.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160708/a7239a4e/attachment.html>
