Building a library for RTEMS
    Sambeet Panigrahi
    sambeet161616 at gmail.com
    Fri Jul 15 23:55:35 UTC 2016
Sir,
I made the necessary changes
First I gave the commmand:
sambeet at Holmes ~/NewRockPort/x86/Build/rock/rtt_test $
/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-g++
-Wall -c displayer.cpp -Ihome/sambeet/NewRockPort/x86/Build/rock/rtt_test/
-I/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/i386-rtems4.11/pc586/lib/include/
This file gave me the required object file
sambeet at Holmes ~/NewRockPort/x86/Build/rock/rtt_test $ ls
displayer.cpp  displayer.o  rtt_hello.hpp  rtt_test.orogen
 rtt_testTypes.hpp
Then I use the archiver
/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-gcc-ar
-cvq libdisplayer.a *.o
But I get the output
/home/sambeet/NewRockPort/x86/Install/rtems/4.11.0-rc3/bin/i386-rtems4.11-gcc-ar:
Cannot find plugin 'liblto_plugin.so'
I found that this plugin is finds the LTO wrapper for linker time
optimization.I found the LTO wrapper though inside gcc.I tried to disable
linker optimization but with no success.
-cvq -fno-use-linker-plugin libdisplayer.a *.o
How do I resolve this error?
On Fri, Jul 15, 2016 at 5:11 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 15/07/2016 06:19, Sambeet Panigrahi wrote:
>> When I am trying to compile the above I get a link failure error:
> This command creates an executable. What you are seeing are the linker
> errors because you have not provided a suitable path to the RTEMS libraries
> for your BSP. To make a library you need to create an object file and then
> create a library containing that file.
> How can I build my library and create an executable for i386-rtems?
> I suggest you search the net for ways to do this. A quick google gave me ..
> http://www.cs.dartmouth.edu/~campbell/cs50/buildlib.html
> RTEMS is statically linked so we only use static libraries, ie .a files.
> You need to substitute 'mygcc' and 'gcc' with 'i386-rtems4.11-g++' and 'ar'
> with 'i386-rtems4.11-ar'.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20160716/48c906d8/attachment.html>
