dlopen failed: file not found
Thu Jul 28 02:22:17 UTC 2016
On 28/07/2016 08:05, Saeed Ehteshamifar wrote:
> Hello,
> I followed the instructions Chris posted on using WAF to make a TAR
> object file and linked it to my program. But when I run it, I get "file
> not found" error. I'm using SPARC SIS.
> Here is my waf script:
> import rtems_waf.rtems as rtems
> def init(ctx):
>      rtems.init(ctx)
> def options(opt):
>      rtems.options(opt)
> def configure(conf):
>      rtems.configure(conf)
> def build(bld):
>      rtems.build(bld)
>      rtems.root_filesystem(bld, 'dl',
>          ['init.c',
>          'hello.c'],
>          'dl.tar', 'dl-tar.o')
How do you build the tar file into the executable?
> And here is how I untar the object in my Init task and load the dynamic
> object, which should print "Hello":
> extern int _binary_dl_tar_start;
> extern int _binary_dl_tar_size;
> rtems_task Init(
>    rtems_task_argument ignored
>    int (*hello)();
>    int te = Untar_FromMemory((void *)(&_binary_dl_tar_start),
>                          (size_t)(_binary_dl_tar_size));
>    /* error checking. omitted here. */
I suggest you print the error code here.
>    void* handle = dlopen ("/hello.o", RTLD_NOW | RTLD_GLOBAL);
>    if (!handle)
>      printf("dlopen failed: %s\n", dlerror());
>      exit(1);
> What am I doing wrong? Using /objdump/ and /nm/ I didn't find ANY
> occurrence of /hello /in the final executable file.
> Best Regards,
> Saeed
> users mailing list
> users at rtems.org
