RTEMS 4.11 Sparc (GCC 4.9.3 20160626) - cxx_throw example error.
Thu Jul 28 14:36:22 UTC 2016
Can you send a patch to devel at rtems.org?
On Thu, Jul 28, 2016 at 4:39 AM, Thomas Kim <thomas73.kim at gmail.com> wrote:
> Dear Sir,
> I found the reason.
> There is a problem for creating semaphore in rtems_gxx_mutex_init() of
> gxx_wrappers.c.
> Because rtems_semaphore_create() return FAIL, _Terminate() function is
> called.
> I added CONFIGURE_MAXIMUM_SEMAPHORES value in cxx example.
> Best Regards,
> Thomas Kim
> 2016-07-28 14:28 GMT+09:00 Thomas Kim <thomas73.kim at gmail.com>:
>> Dear Sir,
>> I used RTEMS 4.10.99 version for Sparc using GCC 4.8.2 until now.
>> Also, I integrated C++ software very well on this RTEMS versiion.
>> I am tring to upgrade below version. and, my C++ software will be
>> integrated with updated RTEMS version.
>>   1) RTEMS 4.11.99 (GCC 4.9.3 20150626 for RTEMS 4.11)
>>   2) RTEMS 4.11.99 (GCC 6.1.1 20160609 for RTEMS 4.12)
>> First of all, I am testing RTEMS on Sparc simulator using
>> sparc-rtems4.xx-sis.
>> Because RTEMS 4.11.99 using GCC 6.1.1 for RTEMS 4.12 have a run-time error
>> for testing ticker.exe example, I am testing RTEMS 4.11.99 using GCC 4.9.3
>> for RTEMS 4.11.
>> At this time, ticker.exe is run very well on RTEMS 4.11.99 using GCC 4.9.3
>> for RTEMS 4.11.
>> also, when I test cxx_throw example on this RTEMS, error message is below;
>> $ sparc-rtems4.11-sis -leon3 cxx_throw/o-optimize/cxx_throw.exe
>>  SIS - SPARC instruction simulator 2.8,  copyright Jiri Gaisler 1995
>>  Bug-reports to jiri at gaisler.se
>>  LEON3 emulation enabled
>> sis> run
>> IU in error mode (128)
>>    148455  4003f4a0  91d02000  ta  0
>> sis>
>> On referencing, I resolved this(cxx_throw example test) on RTEMS 4.10.99
>> using GCC 4.8.2 according to below guide-line.
>> <leon3.cfg>
>> - LDFLAGS = -Wl,--gc-sections#CFLAGS_OPTIMIZE_V += -ffunction-sections
>> -fdata-sections
>> + #LDFLAGS = -Wl,--gc-sections#CFLAGS_OPTIMIZE_V += -ffunction-sections
>> -fdata-sections
>> At this time, even though I patched same method, cxx_throw example is not
>> run.
>> Please let me know how to resolve for testing cxx_throw example using
>> RTEMS 4.11(GCC 4.9.3 20160626).
>> Best Regards,
>> Thomas Kim.
> users mailing list
> users at rtems.org
