Name of a BSP
Joel Sherrill
joel at rtems.org
Tue Jul 5 14:42:05 UTC 2016
FYI rtems-bsps is still broken. I know we have discussed this
before but I don't remember how to fix the find statement.
Also it says 4.11. :)
[joel at localhost rtems]$ ./rtems-bsps
find: paths must precede expression: 5
Usage: find [-H] [-L] [-P] [-Olevel] [-D
help|tree|search|stat|rates|opt|exec] [path...] [expression]
RTEMS 4.11
Architectures: 0
BSP Count: 0
On Tue, Jul 5, 2016 at 5:28 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 5/07/2016 7:52 PM, Ruhollah Majdoddin wrote:
> > It is not documented what the "name" of a (Board Support Package) BSP is.
> > For example, trying to configure RTEMS for Atmel SAM family, I had to
> > provide the BSP name to the --enable-rtemsbsp option.
> > As The source of BSP is in directory
> > c/src/lib/libbsp/arm/atsam
> > I assumed that the name is "atsam", which did not work. After lots of
> > trying, accidentally I found the file
> > c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
> > and guessed that the the name should be "atsamv", which worked.
> Try running 'rtems-bsp' in the top of the source tree. It will list all
> the BSP in the source tree.
> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160705/f9b4299e/attachment-0002.html>
