On 06/07/2016 01:44, Joel Sherrill wrote: > Thanks. Pushed a fix for that and changed the version number to 4.12. I only saw the version change in the patch... https://lists.rtems.org/pipermail/vc/2016-July/010825.html Also I think the 5 is needed so '-depth -maxdepth 5' is needed for GNU find. BSD documents '-depth n'. I need to test on 4 different hosts to know. Chris
