select() ?
Michael Westfall
mwestfal at gemini.edu
Fri Jun 10 13:11:03 UTC 2016
Oh thanks.
it turns out I was confused about a couple things, but I see now that
<sys/select.h> exists under the BSP, and the select() call is there...
Thanks again, and I'll go back to the future now. :-)
On Thu, Jun 9, 2016 at 8:09 PM, Paul Whitfield <paulw at omnitronics.com.au>
wrote:
> Hi Mike,
> Assuming you actually mean Trams 4.10.2 and you are not from 50 years in
> the future J
> Yes RTEMS 4.10.2 has select.
> Yes the definition is in <sys/select.h>
> If you don’t have the include file, I suspect something has gone wrong in
> your RTEMS build process.
> How are you building RTEMS?
> Regards
> Paul Whitfield
> *From:* users [mailto:users-bounces at rtems.org] *On Behalf Of *Michael
> Westfall
> *Sent:* Friday, 10 June 2016 4:23 AM
> *To:* users at rtems.org
> *Subject:* select() ?
> We're using RTEMS 10.4.2
> Does RTEMS have a select() function? I was pretty sure it did, but I have
> grep'd the include directory, and I can't find it in any of the header
> files.
> Should be in <sys/select.h>, right? But we don't have a <sys/select.h>, it
> seems.
> Was there some option that needed to specified when we built RTEMS?
> Thanks.....
> Mike Westfall
> Control Systems Software Engineer
Mike Westfall
URL: <http://lists.rtems.org/pipermail/users/attachments/20160610/b9e3d28b/attachment.html>
