Standard RTEMS NFSv3 client now available via libbsd
Mon Jun 13 12:33:23 UTC 2016
On 10/06/16 16:47, Till Straumann wrote:
> The client is V2, not V3.
Thanks for clarification, this explains why its necessary to enable a
legacy mode on one NFS server to be able to work with RTEMS clients.
> We have a low-priority project to add V3 but having a low priority I'm
> not sure if or when it's going to happen...
Another option would be to port the FreeBSD NFS client to RTEMS. For
this we need a FreeBSD kernel file system layer to RTEMS file system
layer adaptor.
> - Till
> On 06/10/2016 05:20 AM, Sebastian Huber wrote:
>> Hello,
>> I imported a snapshot of the standard RTEMS NFSv3 client from Till
>> Straumann to the libbsd (the new network stack). The RPC deamon uses
>> a kqueue() instead of RTEMS events for synchronization. The zero-copy
>> optimization by means of direct usage of mbufs is currently not
>> available due to a lack of time and budget.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
