Getting a raw rtems_cpu_usage_report
Joel Sherrill
joel at rtems.org
Thu Jun 16 12:50:58 UTC 2016
On Jun 16, 2016 7:37 AM, "Jan Sommer" <soja-lists at aries.uberspace.de> wrote:
> Hello,
> In rtems 4.10.2 there is the possibility to get a CPU usage report, but
it looks like it's only possible to get it as a formatted text.
> We only communicate via a certain protocol with our device, thus the
formatted text is not really useful.
> Is there a way to retrieve a copy of the CPU usage report as some kind of
data type (array of structs)?
> Then, we could filter and format the desired information from that and
send the results back in a packet.
Yep. I have mentioned this as a desirable feature in nearly every RTEMS
class I have taught for over a decade. Your requirements are common. I have
heard of people writing the report to a file and parsing that.
It is a great opportunity to contribute or sponsor a core developer to do
the work.
It needs an API with a data structure defined. Could be two. One to get a
single thread's info with an ID and another way to iterate over all threads
with your own method called.
Personally I would have added to RTEMS before writing the report to a file
and parsing it. But I haven't been given the opportunity.
Also I think the user should be able to configure a stack checker plugin to
report a blown stack. That should be mostly refactoring.
Two things I thing are needed but no one has moved yet.
--joel
> Best regards,
> Jan
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160616/e7e36e64/attachment.html>
