Issue with RTEMS 4.12 compiler include path
Wed Jun 22 17:30:02 UTC 2016
I was not clear, what was your Makefile, or how do you build your
"very simple application"? Perhaps you can provide it as a compressed
folder.
On Wed, Jun 22, 2016 at 11:59 AM, John Harwell <jharwell at swri.org> wrote:
> Here is the Makefile that configure generated. Hope this helps.
> On 06/22/2016 10:53 AM, Gedare Bloom wrote:
>> What is your makefile?
>> On Tue, Jun 21, 2016 at 3:15 PM, John Harwell <jharwell at swri.org> wrote:
>>> Hello,
>>> I have been able to successfully build what I think is the SMP version of
>>> RTEMS 4.12 for SPARC by downloading and building the tools:
>>> ../source-builder/sb-set-builder --prefix=/opt/rtems-4.12
>>> 4.12/rtems-sparc
>>> And configuring, building, and installing RTEMS:
>>> ../rtems/configure --prefix=/opt/rtems-4.12 --target=sparc-rtems4.12
>>> --enable-posix --enable-rtemsbsp="leon3" --enable-tests=samples
>>> --enable-smp
>>> CONSOLE_USE_INTERRUPTS=0
>>> make install
>>> I got the configure line from a README I found on the Gaisler site.
>>> However, after building RTEMS and then attempting to build a very simple
>>> application consisting only of an empty Init(), I get the following error
>>> message:
>>> fatal error: rtems.h: No such file or directory
>>> I  do have rtems.h in /opt/rtems-4.12/sparc-rtems/leon3/lib/include, but
>>> that path is not in the compiler built-in search path. I can get around
>>> this
>>> but manually adding this directory to the include path, but I'm wondering
>>> if
>>> I configured something incorrectly in the build process which caused this
>>> to
>>> happen.
>>> Here is the information of the compiler:
>>> Using built-in specs.
>>> COLLECT_GCC=/opt/rtems-4.12/bin/sparc-rtems4.12-gcc
>>> Target: sparc-rtems4.12
>>> Configured with: ../gcc-6-20160609/configure --prefix=/opt/rtems-4.12
>>> --bindir=/opt/rtems-4.12/bin --exec_prefix=/opt/rtems-4.12
>>> --includedir=/opt/rtems-4.12/include --libdir=/opt/rtems-4.12/lib
>>> --libexecdir=/opt/rtems-4.12/libexec --mandir=/opt/rtems-4.12/share/man
>>> --infodir=/opt/rtems-4.12/share/info --datadir=/opt/rtems-4.12/share
>>> --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=sparc-rtems4.12
>>> --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose
>>> --with-newlib
>>> --with-system-zlib --disable-nls --without-included-gettext
>>> --disable-win32-registry --enable-version-specific-runtime-libs
>>> --disable-lto --enable-newlib-io-c99-formats --enable-newlib-iconv
>>> --enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
>>> --enable-threads --disable-plugin --enable-libgomp
>>> --enable-languages=c,c++
>>> Thread model: rtems
>>> gcc version 6.1.1 20160609 (RTEMS 4.12, RSB
>>> c476de6150f39afdf142c6f4420c59ba2f1aa2fe, Newlib 2.4.0.20160527) (GCC)
>>> COLLECT_GCC_OPTIONS='-E' '-v' '-mcpu=v7'
>>>   /opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/cc1 -E -quiet -v -
>>> -mcpu=v7
>>> ignoring nonexistent directory
>>> "/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/sys-include"
>>> #include "..." search starts here:
>>> #include <...> search starts here:
>>>   /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/include
>>>   /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/include-fixed
>>> /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/include
>>> End of search list.
>>> # 1 "<stdin>"
>>> # 1 "<built-in>"
>>> # 1 "<command-line>"
>>> # 1 "<stdin>"
>>> COMPILER_PATH=/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/bin/
>>> LIBRARY_PATH=/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/lib/
>>> Thanks,
>>> John Harwell
>>> Southwest Research Institute
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
