Issue with RTEMS 4.12 compiler include path
Thu Jun 23 13:25:27 UTC 2016
On 23/06/16 15:17, Harwell, John R. wrote:
> Thanks Sebastian--I have updated my Makefile. I'm still having problems with the compiler builtin include path when building though. I've been poking around the RSB configuration, but cannot figure out how to add an additional system include directory when building the compiler. I looked at the logs, and the '--with-sysroot=' option looked like it might be what I wanted, but passing it to the toolchain build process did not have any effect. Do you have any ideas there?
I use the attached Makefile for simple programs. There is waf support
for RTEMS applications, which is probably the better alternative.
I would not build a special GCC for such purposes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
