select() ?
Paul Whitfield
paulw at omnitronics.com.au
Fri Jun 10 00:09:59 UTC 2016
Hi Mike,
Assuming you actually mean Trams 4.10.2 and you are not from 50 years in the future ☺
Yes RTEMS 4.10.2 has select.
Yes the definition is in <sys/select.h>
If you don’t have the include file, I suspect something has gone wrong in your RTEMS build process.
How are you building RTEMS?
Regards
Paul Whitfield
From: users [mailto:users-bounces at rtems.org] On Behalf Of Michael Westfall
Sent: Friday, 10 June 2016 4:23 AM
To: users at rtems.org
Subject: select() ?
We're using RTEMS 10.4.2
Does RTEMS have a select() function? I was pretty sure it did, but I have grep'd the include directory, and I can't find it in any of the header files.
Should be in <sys/select.h>, right? But we don't have a <sys/select.h>, it seems.
Was there some option that needed to specified when we built RTEMS?
Thanks.....
Mike Westfall
Control Systems Software Engineer
[http://www.gemini.edu/images/GeminiLogo_4.5in_newSmall.png]
URL: <http://lists.rtems.org/pipermail/users/attachments/20160610/8458932d/attachment-0002.html>
