USE_COM1_AS_CONSOLE=1 not effective
Saeed Ehteshamifar salpha.2004 at gmail.com
Wed Jun 15 00:40:36 UTC 2016
> What qemu command are you using?
*-kernel *
I haven't tried booting RTEMS via grub. How should I make a grub-bootable
QEMU disk image? The process seems to be a bit tricky; I followed several
guides on the Internet but none is working. Is there any guide on rtems
wiki?
Update about kernel config options:
I tried configuring with *BSP_ENABLE_VGA=0 BSP_ENABLE_COM1_COM4=1
BSP_USE_COM1_AS_CONSOLE=1*
and I got the following (still no output to stdio but booting source
changes!):
[image: Inline image 1]
On Tue, Jun 14, 2016 at 7:50 PM, Joel Sherrill <joel at rtems.org> wrote:
> Chris might have broken this with his recent changes. But more likely....
> I think Gedare's problem was that his grubmenu was not updated to this:
> kernel= (hd0,0)/test.exe --console=/dev/com1
> Before Chris' recent changes, the line would have read:
> kernel= (hd0,0)/test.exe --console=com1
> Notice the missing "/dev/" on --console. It greatly simplified the boot
> argument parsing but requires boot args to be updated.
> I asked for Gedare's opinion on another thread as to whether we need
> to keep backwards compatibility but I don't think he has answered.
> --joel
> On Tue, Jun 14, 2016 at 11:22 AM, Saeed Ehteshamifar <
> salpha.2004 at gmail.com> wrote:
>> I've just seen Gedare's problem with this also, which was unfortunately
>> unsolved. :(
>> On Tue, Jun 14, 2016 at 6:20 PM, Saeed Ehteshamifar <
>>> Hi,
>>> It seems that USE_COM1_AS_CONSOLE=1 is not effective for me. I'm
>>> configuring RTEMS with this option (bsp: pc386) and as a result, in my BSP
>>> install directory (specified by --prefix), I have:
>>> *./i386-rtems4.12/pc386/lib/include/bspopts.h:#define
>>> USE_COM1_AS_CONSOLE 1*
>>> However, when I run the hello example, nothing is output to the screen:
>>> *qemu-system-i386 -kernel $(find . -name hello.exe) -serial stdio
>>> -monitor null -nographic*
>>> Below is a screenshot of QEMU, which suggests that both Console and
>>> printk are  using /dev/vgacons. Does this imply that the USE_COM... is
>>> taken as not effective?
>>> And how should I correctly configure RTEMS to put the output to COM1 for
>>> pc386?
>>> Thanks!
>>> Best Regards,
>>> Saeed
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160615/b3bc4852/attachment-0002.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160615/b3bc4852/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160615/b3bc4852/attachment-0005.png>
