libbsd - rtems_bsd_initialize() startup failure.
Thomas Kim thomas73.kim at gmail.com
Thu Jun 16 23:32:24 UTC 2016
Dear Sebastian,
Thank you very much.
I resolved this by your help. my problem was configuration issue.
Best Regards,
Thomas
2016-06-14 20:06 GMT+09:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 14/06/16 12:25, Thomas Kim wrote:
>> Dear Sir,
>> I have used RTEMS only for one year. Thank you very much.
>> But, I started to integrate libbsd right now. I am beginner about libbsd.
>> After I test libbsd library in my code, console output is below;
>> *** BSD PANIC *** rtems_bsd_threads_init_early: cannot create extension.
> I strongly recommend to use a debugger to figure out problems like this
> (e.g. via a stack trace).
> You need enough resources for the libbsd. You can find a general purpose
> configuration for example in the libbsd test suite. In this particular case
> a user extension is missing (CONFIGURE_MAXIMUM_USER_EXTENSIONS).
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160617/79687c01/attachment-0002.html>
