"Exception handler called for exception 3 (0x3)"
Till Straumann
strauman at slac.stanford.edu
Tue Jun 21 15:50:20 UTC 2016
Look at the ppc documentation. The exception number is the
machine interrupt/exception vector right shifted by 8 bits.
3 therefore corresponds to vector 0x300 "data storage interrupt".
The most likely cause is a bad address which is not mapped or
(e.g., write-) protected. The violating address is stored in the DAR
register
(which is hopefully dumped by the exception handler)
HTH
- Till
On 06/21/2016 08:22 AM, Michael Westfall wrote:
> Where can Iook to find out what an "exception 3" is?
> We're using the mvme2307 BSP, if that makes any difference.
> Thanks,
> Mike Westfall
> Control Systems Software Engineer
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20160621/cb307ccf/attachment-0002.html>
