Issue with RTEMS 4.12 compiler include path
John Harwell jharwell at swri.org
Wed Jun 22 15:59:49 UTC 2016
Here is the Makefile that configure generated. Hope this helps.
On 06/22/2016 10:53 AM, Gedare Bloom wrote:
> What is your makefile?
> On Tue, Jun 21, 2016 at 3:15 PM, John Harwell <jharwell at swri.org> wrote:
>> Hello,
>> I have been able to successfully build what I think is the SMP version of
>> RTEMS 4.12 for SPARC by downloading and building the tools:
>> ../source-builder/sb-set-builder --prefix=/opt/rtems-4.12 4.12/rtems-sparc
>> And configuring, building, and installing RTEMS:
>> ../rtems/configure --prefix=/opt/rtems-4.12 --target=sparc-rtems4.12
>> --enable-posix --enable-rtemsbsp="leon3" --enable-tests=samples --enable-smp
>> CONSOLE_USE_INTERRUPTS=0
>> make install
>> I got the configure line from a README I found on the Gaisler site.
>> However, after building RTEMS and then attempting to build a very simple
>> application consisting only of an empty Init(), I get the following error
>> message:
>> fatal error: rtems.h: No such file or directory
>> I  do have rtems.h in /opt/rtems-4.12/sparc-rtems/leon3/lib/include, but
>> that path is not in the compiler built-in search path. I can get around this
>> but manually adding this directory to the include path, but I'm wondering if
>> I configured something incorrectly in the build process which caused this to
>> happen.
>> Here is the information of the compiler:
>> Using built-in specs.
>> COLLECT_GCC=/opt/rtems-4.12/bin/sparc-rtems4.12-gcc
>> Target: sparc-rtems4.12
>> Configured with: ../gcc-6-20160609/configure --prefix=/opt/rtems-4.12
>> --bindir=/opt/rtems-4.12/bin --exec_prefix=/opt/rtems-4.12
>> --includedir=/opt/rtems-4.12/include --libdir=/opt/rtems-4.12/lib
>> --libexecdir=/opt/rtems-4.12/libexec --mandir=/opt/rtems-4.12/share/man
>> --infodir=/opt/rtems-4.12/share/info --datadir=/opt/rtems-4.12/share
>> --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=sparc-rtems4.12
>> --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld --verbose --with-newlib
>> --with-system-zlib --disable-nls --without-included-gettext
>> --disable-win32-registry --enable-version-specific-runtime-libs
>> --disable-lto --enable-newlib-io-c99-formats --enable-newlib-iconv
>> --enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,win_1253,win_1254,win_1255,win_1256,win_1257,win_1258
>> --enable-threads --disable-plugin --enable-libgomp --enable-languages=c,c++
>> Thread model: rtems
>> gcc version 6.1.1 20160609 (RTEMS 4.12, RSB
>> c476de6150f39afdf142c6f4420c59ba2f1aa2fe, Newlib 2.4.0.20160527) (GCC)
>> COLLECT_GCC_OPTIONS='-E' '-v' '-mcpu=v7'
>>   /opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/cc1 -E -quiet -v -
>> -mcpu=v7
>> ignoring nonexistent directory
>> "/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/sys-include"
>> #include "..." search starts here:
>> #include <...> search starts here:
>>   /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/include
>>   /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/include-fixed
>> /opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/include
>> End of search list.
>> # 1 "<stdin>"
>> # 1 "<built-in>"
>> # 1 "<command-line>"
>> # 1 "<stdin>"
>> COMPILER_PATH=/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/libexec/gcc/sparc-rtems4.12/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/bin/
>> LIBRARY_PATH=/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/:/opt/rtems-4.12/lib/gcc/sparc-rtems4.12/6.1.1/../../../../sparc-rtems4.12/lib/
>> Thanks,
>> John Harwell
>> Southwest Research Institute
>> users mailing list
>> users at rtems.org
# Makefile.in generated by automake 1.14.1 from Makefile.am.
# Makefile.  Generated from Makefile.in by configure.
# Copyright (C) 1994-2013 Free Software Foundation, Inc.
# This Makefile.in is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
# PARTICULAR PURPOSE.
# top level directory for RTEMS build tree
VPATH = ../rtems
am__is_gnu_make = test -n '$(MAKEFILE_LIST)' && test -n '$(MAKELEVEL)'
am__make_running_with_option = \
  case $${target_option-} in \
      *) echo "am__make_running_with_option: internal error: invalid" \
              "target option '$${target_option-}' specified" >&2; \
         exit 1;; \
  esac; \
  has_opt=no; \
  sane_makeflags=$$MAKEFLAGS; \
  if $(am__is_gnu_make); then \
    sane_makeflags=$$MFLAGS; \
  else \
    case $$MAKEFLAGS in \
        bs=\\; \
        sane_makeflags=`printf '%s\n' "$$MAKEFLAGS" \
          | sed "s/$$bs$$bs[$$bs $$bs	]*//g"`;; \
    esac; \
  fi; \
  skip_next=no; \
  strip_trailopt () \
    flg=`printf '%s\n' "$$flg" | sed "s/$$1.*$$//"`; \
  for flg in $$sane_makeflags; do \
    test $$skip_next = yes && { skip_next=no; continue; }; \
    case $$flg in \
      *=*|--*) continue;; \
        -*I) strip_trailopt 'I'; skip_next=yes;; \
      -*I?*) strip_trailopt 'I';; \
        -*O) strip_trailopt 'O'; skip_next=yes;; \
      -*O?*) strip_trailopt 'O';; \
        -*l) strip_trailopt 'l'; skip_next=yes;; \
      -*l?*) strip_trailopt 'l';; \
      -[dEDm]) skip_next=yes;; \
      -[JT]) skip_next=yes;; \
    esac; \
    case $$flg in \
      *$$target_option*) has_opt=yes; break;; \
    esac; \
  done; \
  test $$has_opt = yes
am__make_dryrun = (target_option=n; $(am__make_running_with_option))
am__make_keepgoing = (target_option=k; $(am__make_running_with_option))
pkgincludedir = $(includedir)/rtems
pkglibdir = $(libdir)/rtems
pkglibexecdir = $(libexecdir)/rtems
am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
install_sh_DATA = $(install_sh) -c -m 644
install_sh_PROGRAM = $(install_sh) -c
install_sh_SCRIPT = $(install_sh) -c
INSTALL_HEADER = $(INSTALL_DATA)
transform = $(program_transform_name)
NORMAL_INSTALL = :
PRE_INSTALL = :
POST_INSTALL = :
NORMAL_UNINSTALL = :
PRE_UNINSTALL = :
POST_UNINSTALL = :
build_triplet = x86_64-pc-linux-gnu
host_triplet = x86_64-pc-linux-gnu
target_triplet = sparc-unknown-rtems4.12
DIST_COMMON = $(top_srcdir)/automake/subdirs.am \
	$(top_srcdir)/automake/host.am $(srcdir)/Makefile.in \
	$(srcdir)/Makefile.am $(top_srcdir)/configure \
	$(am__configure_deps) $(dist_rtems_make_DATA) \
	$(dist_rtems_make_Templates_DATA) \
	$(dist_rtems_make_custom_DATA) COPYING INSTALL README compile \
	config.guess config.sub depcomp install-sh mdate-sh missing \
	texinfo.tex
subdir = .
ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
am__aclocal_m4_deps = $(top_srcdir)/aclocal/enable-cxx.m4 \
	$(top_srcdir)/aclocal/enable-drvmgr.m4 \
	$(top_srcdir)/aclocal/enable-multiprocessing.m4 \
	$(top_srcdir)/aclocal/enable-networking.m4 \
	$(top_srcdir)/aclocal/enable-paravirt.m4 \
	$(top_srcdir)/aclocal/enable-posix.m4 \
	$(top_srcdir)/aclocal/enable-rtems-debug.m4 \
	$(top_srcdir)/aclocal/enable-rtemsbsp.m4 \
	$(top_srcdir)/aclocal/enable-tests.m4 \
	$(top_srcdir)/aclocal/multilib.m4 \
	$(top_srcdir)/aclocal/rtems-top.m4 \
	$(top_srcdir)/aclocal/version.m4 $(top_srcdir)/acinclude.m4 \
	$(top_srcdir)/configure.ac
am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
	$(ACLOCAL_M4)
am__CONFIG_DISTCLEAN_FILES = config.status config.cache config.log \
 configure.lineno config.status.lineno
mkinstalldirs = $(install_sh) -d
CONFIG_CLEAN_FILES =
CONFIG_CLEAN_VPATH_FILES =
SCRIPTS = $(noinst_SCRIPTS)
AM_V_P = $(am__v_P_$(V))
am__v_P_ = $(am__v_P_$(AM_DEFAULT_VERBOSITY))
am__v_P_0 = false
am__v_P_1 = :
AM_V_GEN = $(am__v_GEN_$(V))
am__v_GEN_ = $(am__v_GEN_$(AM_DEFAULT_VERBOSITY))
am__v_GEN_0 = @echo "  GEN     " $@;
am__v_GEN_1 =
AM_V_at = $(am__v_at_$(V))
am__v_at_ = $(am__v_at_$(AM_DEFAULT_VERBOSITY))
am__v_at_0 = @
am__v_at_1 =
SOURCES =
DIST_SOURCES =
RECURSIVE_TARGETS = all-recursive check-recursive cscopelist-recursive \
	ctags-recursive dvi-recursive html-recursive info-recursive \
	install-data-recursive install-dvi-recursive \
	install-exec-recursive install-html-recursive \
	install-info-recursive install-pdf-recursive \
	install-ps-recursive install-recursive installcheck-recursive \
	installdirs-recursive pdf-recursive ps-recursive \
	tags-recursive uninstall-recursive
am__can_run_installinfo = \
  case $$AM_UPDATE_INFO_DIR in \
    n|no|NO) false;; \
    *) (install-info --version) >/dev/null 2>&1;; \
  esac
am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`;
am__vpath_adj = case $$p in \
    $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \
    *) f=$$p;; \
  esac;
am__strip_dir = f=`echo $$p | sed -e 's|^.*/||'`;
am__install_max = 40
am__nobase_strip_setup = \
  srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*|]/\\\\&/g'`
am__nobase_strip = \
  for p in $$list; do echo "$$p"; done | sed -e "s|$$srcdirstrip/||"
am__nobase_list = $(am__nobase_strip_setup); \
  for p in $$list; do echo "$$p $$p"; done | \
  sed "s| $$srcdirstrip/| |;"' / .*\//!s/ .*/ ./; s,\( .*\)/[^/]*$$,\1,' | \
  $(AWK) 'BEGIN { files["."] = "" } { files[$$2] = files[$$2] " " $$1; \
    if (++n[$$2] == $(am__install_max)) \
      { print $$2, files[$$2]; n[$$2] = 0; files[$$2] = "" } } \
    END { for (dir in files) print dir, files[dir] }'
am__base_list = \
  sed '$$!N;$$!N;$$!N;$$!N;$$!N;$$!N;$$!N;s/\n/ /g' | \
  sed '$$!N;$$!N;$$!N;$$!N;s/\n/ /g'
am__uninstall_files_from_dir = { \
  test -z "$$files" \
    || { test ! -d "$$dir" && test ! -f "$$dir" && test ! -r "$$dir"; } \
    || { echo " ( cd '$$dir' && rm -f" $$files ")"; \
         $(am__cd) "$$dir" && rm -f $$files; }; \
am__installdirs = "$(DESTDIR)$(rtems_makedir)" \
	"$(DESTDIR)$(rtems_make_Templatesdir)" \
	"$(DESTDIR)$(rtems_make_customdir)"
DATA = $(dist_rtems_make_DATA) $(dist_rtems_make_Templates_DATA) \
RECURSIVE_CLEAN_TARGETS = mostlyclean-recursive clean-recursive	\
  distclean-recursive maintainer-clean-recursive
am__recursive_targets = \
  $(RECURSIVE_TARGETS) \
  $(RECURSIVE_CLEAN_TARGETS) \
  $(am__extra_recursive_targets)
AM_RECURSIVE_TARGETS = $(am__recursive_targets:-recursive=) TAGS CTAGS \
	cscope distdir dist dist-all distcheck
am__tagged_files = $(HEADERS) $(SOURCES) $(TAGS_FILES) $(LISP)
# Read a list of newline-separated strings from the standard input,
# and print each of them once, without duplicates.  Input order is
# *not* preserved.
am__uniquify_input = $(AWK) '\
  BEGIN { nonempty = 0; } \
  { items[$$0] = 1; nonempty = 1; } \
  END { if (nonempty) { for (i in items) print i; }; } \
# Make sure the list of sources is unique.  This is necessary because,
# e.g., the same source file might be shared among _SOURCES variables
# for different programs/libraries.
am__define_uniq_tagged_files = \
  list='$(am__tagged_files)'; \
  unique=`for i in $$list; do \
    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
  done | $(am__uniquify_input)`
ETAGS = etags
CTAGS = ctags
CSCOPE = cscope
DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
distdir = $(PACKAGE)-$(VERSION)
top_distdir = $(distdir)
am__remove_distdir = \
  if test -d "$(distdir)"; then \
    find "$(distdir)" -type d ! -perm -200 -exec chmod u+w {} ';' \
      && rm -rf "$(distdir)" \
      || { sleep 5 && rm -rf "$(distdir)"; }; \
  else :; fi
am__post_remove_distdir = $(am__remove_distdir)
am__relativize = \
  dir0=`pwd`; \
  sed_first='s,^\([^/]*\)/.*$$,\1,'; \
  sed_rest='s,^[^/]*/*,,'; \
  sed_last='s,^.*/\([^/]*\)$$,\1,'; \
  sed_butlast='s,/*[^/]*$$,,'; \
  while test -n "$$dir1"; do \
    first=`echo "$$dir1" | sed -e "$$sed_first"`; \
    if test "$$first" != "."; then \
      if test "$$first" = ".."; then \
        dir2=`echo "$$dir0" | sed -e "$$sed_last"`/"$$dir2"; \
        dir0=`echo "$$dir0" | sed -e "$$sed_butlast"`; \
      else \
        first2=`echo "$$dir2" | sed -e "$$sed_first"`; \
        if test "$$first2" = "$$first"; then \
          dir2=`echo "$$dir2" | sed -e "$$sed_rest"`; \
        else \
          dir2="../$$dir2"; \
        fi; \
        dir0="$$dir0"/"$$first"; \
      fi; \
    fi; \
    dir1=`echo "$$dir1" | sed -e "$$sed_rest"`; \
  done; \
  reldir="$$dir2"
GZIP_ENV = --best
DIST_ARCHIVES = $(distdir).tar.bz2
DIST_TARGETS = dist-bzip2
distuninstallcheck_listfiles = find . -type f -print
am__distuninstallcheck_listfiles = $(distuninstallcheck_listfiles) \
  | sed 's|^\./|$(prefix)/|' | grep -v '$(infodir)/dir$$'
distcleancheck_listfiles = find . -type f -print
pkgdatadir = ${datarootdir}/rtems4.12
ACLOCAL = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/missing aclocal-1.14
AMTAR = $${TAR-tar}
AM_DEFAULT_VERBOSITY = 1
AUTOCONF = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/missing autoconf
AUTOHEADER = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/missing autoheader
AUTOMAKE = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/missing automake-1.14
AWK = gawk
CYGPATH_W = echo
DEFS = -DPACKAGE_NAME=\"rtems\" -DPACKAGE_TARNAME=\"rtems\" -DPACKAGE_VERSION=\"4.11.99.0\" -DPACKAGE_STRING=\"rtems\ 4.11.99.0\" -DPACKAGE_BUGREPORT=\"https://devel.rtems.org/newticket\" -DPACKAGE_URL=\"\"
ECHO_C =
ECHO_N = -n
ECHO_T =
INSTALL = /usr/bin/install -c
INSTALL_DATA = ${INSTALL} -m 644
INSTALL_PROGRAM = ${INSTALL}
INSTALL_SCRIPT = ${INSTALL}
INSTALL_STRIP_PROGRAM = $(install_sh) -c -s
LIBOBJS =
LIBS =
LTLIBOBJS =
MAINT = #
MAKE = make
MAKEINFO = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/missing makeinfo
MKDIR_P = /bin/mkdir -p
PACKAGE = rtems
PACKAGE_BUGREPORT = https://devel.rtems.org/newticket
PACKAGE_NAME = rtems
PACKAGE_STRING = rtems 4.11.99.0
PACKAGE_TARNAME = rtems
PACKAGE_URL =
PACKAGE_VERSION = 4.11.99.0
PATH_SEPARATOR = :
PROJECT_ROOT = ./$(top_builddir)
PROJECT_TOPdir = ./$(top_builddir)
RTEMS_HAS_NETWORKING = yes
RTEMS_HAS_POSIX_API = yes
RTEMS_TOPdir = .
SET_MAKE =
SHELL = /bin/bash
STRIP =
VERSION = 4.11.99.0
abs_builddir = /home/jharwell/svn/irir/trunk/rtems/build
abs_srcdir = /home/jharwell/svn/irir/trunk/rtems/build/../rtems
abs_top_builddir = /home/jharwell/svn/irir/trunk/rtems/build
abs_top_srcdir = /home/jharwell/svn/irir/trunk/rtems/build/../rtems
am__leading_dot = .
am__tar = $${TAR-tar} chof - "$$tardir"
am__untar = $${TAR-tar} xf -
bindir = ${exec_prefix}/bin
build = x86_64-pc-linux-gnu
build_SUBDIRS =  tools/build tools/cpu testsuites/tools
build_alias =
build_configdirs =  tools/build tools/cpu testsuites/tools
build_cpu = x86_64
build_os = linux-gnu
build_subdir = .
build_vendor = pc
buildargs = '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'  '--enable-posix' '--enable-rtemsbsp=leon3' '--enable-tests=samples' '--enable-smp' 'CONSOLE_USE_INTERRUPTS=0' '--target=sparc-rtems4.12'
builddir = .
datarootdir = ${prefix}/share
docdir = ${datarootdir}/doc/${PACKAGE_TARNAME}
dvidir = ${docdir}
exec_prefix = ${prefix}
host = x86_64-pc-linux-gnu
host_SUBDIRS =
host_alias =
host_configdirs =
host_cpu = x86_64
host_os = linux-gnu
host_subdir =
host_vendor = pc
hostargs = '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12'  '--enable-posix' '--enable-rtemsbsp=leon3' '--enable-tests=samples' '--enable-smp' 'CONSOLE_USE_INTERRUPTS=0'
htmldir = ${docdir}
includedir = ${prefix}/include
infodir = ${datarootdir}/info
install_sh = ${SHELL} /home/jharwell/svn/irir/trunk/rtems/rtems/install-sh
libdir = ${exec_prefix}/lib
libexecdir = ${exec_prefix}/libexec
localedir = ${datarootdir}/locale
localstatedir = ${prefix}/var
mandir = ${datarootdir}/man
mkdir_p = $(MKDIR_P)
oldincludedir = /usr/include
pdfdir = ${docdir}
prefix = /opt/rtems-4.12
program_transform_name = s&^&sparc-rtems4.12-&
psdir = ${docdir}
sbindir = ${exec_prefix}/sbin
sharedstatedir = ${prefix}/com
srcdir = ../rtems
sysconfdir = ${prefix}/etc
target = sparc-unknown-rtems4.12
target_SUBDIRS =  sparc-rtems4.12/c
target_alias = sparc-rtems4.12
target_configdirs =  c
target_cpu = sparc
target_os = rtems4.12
target_subdir = sparc-rtems4.12
target_vendor = unknown
targetargs = '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12'  '--enable-posix' '--enable-rtemsbsp=leon3' '--enable-tests=samples' '--enable-smp' 'CONSOLE_USE_INTERRUPTS=0'
top_build_prefix =
top_builddir = .
top_srcdir = ../rtems
ACLOCAL_AMFLAGS = -I aclocal
SUBDIRS = $(build_SUBDIRS) $(host_SUBDIRS) $(target_SUBDIRS)
DIST_SUBDIRS = $(SUBDIRS)
noinst_SCRIPTS = bootstrap
EXTRA_DIST = README.configure SUPPORT VERSION LICENSE \
	$(noinst_SCRIPTS) config-ml.in ampolish3
rtems_makedir = $(prefix)/make
dist_rtems_make_DATA = make/main.cfg make/leaf.cfg
rtems_make_Templatesdir = $(pkgdatadir)/make/Templates
dist_rtems_make_Templates_DATA = make/Templates/Makefile.dir \
	make/Templates/Makefile.leaf make/Templates/Makefile.lib
rtems_make_customdir = $(rtems_makedir)/custom
dist_rtems_make_custom_DATA = make/custom/default.cfg
all: all-recursive
.SUFFIXES:
am--refresh: Makefile
$(srcdir)/Makefile.in: # $(srcdir)/Makefile.am $(top_srcdir)/automake/subdirs.am $(top_srcdir)/automake/host.am $(am__configure_deps)
	@for dep in $?; do \
	  case '$(am__configure_deps)' in \
	    *$$dep*) \
	      echo ' cd $(srcdir) && $(AUTOMAKE) --foreign'; \
	      $(am__cd) $(srcdir) && $(AUTOMAKE) --foreign \
		&& exit 0; \
	      exit 1;; \
	  esac; \
	done; \
	echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign Makefile'; \
	$(am__cd) $(top_srcdir) && \
.PRECIOUS: Makefile
Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
	@case '$?' in \
	  *config.status*) \
	    echo ' $(SHELL) ./config.status'; \
	    $(SHELL) ./config.status;; \
	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe)'; \
	    cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe);; \
	esac;
$(top_srcdir)/automake/subdirs.am $(top_srcdir)/automake/host.am:
$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
	$(SHELL) ./config.status --recheck
$(top_srcdir)/configure: # $(am__configure_deps)
	$(am__cd) $(srcdir) && $(AUTOCONF)
$(ACLOCAL_M4): # $(am__aclocal_m4_deps)
	$(am__cd) $(srcdir) && $(ACLOCAL) $(ACLOCAL_AMFLAGS)
$(am__aclocal_m4_deps):
install-dist_rtems_makeDATA: $(dist_rtems_make_DATA)
	@$(NORMAL_INSTALL)
	@list='$(dist_rtems_make_DATA)'; test -n "$(rtems_makedir)" || list=; \
	if test -n "$$list"; then \
	  echo " $(MKDIR_P) '$(DESTDIR)$(rtems_makedir)'"; \
	  $(MKDIR_P) "$(DESTDIR)$(rtems_makedir)" || exit 1; \
	fi; \
	for p in $$list; do \
	  if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \
	  echo "$$d$$p"; \
	done | $(am__base_list) | \
	while read files; do \
	  echo " $(INSTALL_DATA) $$files '$(DESTDIR)$(rtems_makedir)'"; \
	  $(INSTALL_DATA) $$files "$(DESTDIR)$(rtems_makedir)" || exit $$?; \
	done
uninstall-dist_rtems_makeDATA:
	@$(NORMAL_UNINSTALL)
	files=`for p in $$list; do echo $$p; done | sed -e 's|^.*/||'`; \
	dir='$(DESTDIR)$(rtems_makedir)'; $(am__uninstall_files_from_dir)
install-dist_rtems_make_TemplatesDATA: $(dist_rtems_make_Templates_DATA)
	@$(NORMAL_INSTALL)
	@list='$(dist_rtems_make_Templates_DATA)'; test -n "$(rtems_make_Templatesdir)" || list=; \
	  echo " $(MKDIR_P) '$(DESTDIR)$(rtems_make_Templatesdir)'"; \
	  $(MKDIR_P) "$(DESTDIR)$(rtems_make_Templatesdir)" || exit 1; \
	fi; \
	  echo "$$d$$p"; \
	  echo " $(INSTALL_DATA) $$files '$(DESTDIR)$(rtems_make_Templatesdir)'"; \
	  $(INSTALL_DATA) $$files "$(DESTDIR)$(rtems_make_Templatesdir)" || exit $$?; \
	done
uninstall-dist_rtems_make_TemplatesDATA:
	dir='$(DESTDIR)$(rtems_make_Templatesdir)'; $(am__uninstall_files_from_dir)
install-dist_rtems_make_customDATA: $(dist_rtems_make_custom_DATA)
	@$(NORMAL_INSTALL)
	@list='$(dist_rtems_make_custom_DATA)'; test -n "$(rtems_make_customdir)" || list=; \
	  echo " $(MKDIR_P) '$(DESTDIR)$(rtems_make_customdir)'"; \
	  $(MKDIR_P) "$(DESTDIR)$(rtems_make_customdir)" || exit 1; \
	fi; \
	  echo "$$d$$p"; \
	  echo " $(INSTALL_DATA) $$files '$(DESTDIR)$(rtems_make_customdir)'"; \
	  $(INSTALL_DATA) $$files "$(DESTDIR)$(rtems_make_customdir)" || exit $$?; \
	done
uninstall-dist_rtems_make_customDATA:
	dir='$(DESTDIR)$(rtems_make_customdir)'; $(am__uninstall_files_from_dir)
# This directory's subdirectories are mostly independent; you can cd
# into them and run 'make' without going through this Makefile.
# To change the values of 'make' variables: instead of editing Makefiles,
# (1) if the variable is set in 'config.status', edit 'config.status'
#     (which will cause the Makefiles to be regenerated when you run 'make');
# (2) otherwise, pass the desired values on the 'make' command line.
$(am__recursive_targets):
	@fail=; \
	if $(am__make_keepgoing); then \
	  failcom='fail=yes'; \
	else \
	  failcom='exit 1'; \
	fi; \
	dot_seen=no; \
	target=`echo $@ | sed s/-recursive//`; \
	case "$@" in \
	  distclean-* | maintainer-clean-*) list='$(DIST_SUBDIRS)' ;; \
	  *) list='$(SUBDIRS)' ;; \
	esac; \
	for subdir in $$list; do \
	  echo "Making $$target in $$subdir"; \
	  if test "$$subdir" = "."; then \
	    dot_seen=yes; \
	    local_target="$$target-am"; \
	  else \
	    local_target="$$target"; \
	  fi; \
	  ($(am__cd) $$subdir && $(MAKE) $(AM_MAKEFLAGS) $$local_target) \
	  || eval $$failcom; \
	done; \
	if test "$$dot_seen" = "no"; then \
	  $(MAKE) $(AM_MAKEFLAGS) "$$target-am" || exit 1; \
	fi; test -z "$$fail"
	$(am__define_uniq_tagged_files); mkid -fID $$unique
tags: tags-recursive
TAGS: tags
tags-am: $(TAGS_DEPENDENCIES) $(am__tagged_files)
	set x; \
	here=`pwd`; \
	if ($(ETAGS) --etags-include --version) >/dev/null 2>&1; then \
	  include_option=--etags-include; \
	  empty_fix=.; \
	else \
	  include_option=--include; \
	  empty_fix=; \
	fi; \
	list='$(SUBDIRS)'; for subdir in $$list; do \
	  if test "$$subdir" = .; then :; else \
	    test ! -f $$subdir/TAGS || \
	      set "$$@" "$$include_option=$$here/$$subdir/TAGS"; \
	  fi; \
	done; \
	$(am__define_uniq_tagged_files); \
	shift; \
	if test -z "$(ETAGS_ARGS)$$*$$unique"; then :; else \
	  test -n "$$unique" || unique=$$empty_fix; \
	  if test $$# -gt 0; then \
	    $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
	      "$$@" $$unique; \
	  else \
	      $$unique; \
	  fi; \
	fi
ctags: ctags-recursive
CTAGS: ctags
ctags-am: $(TAGS_DEPENDENCIES) $(am__tagged_files)
	test -z "$(CTAGS_ARGS)$$unique" \
	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
	     $$unique
GTAGS:
	here=`$(am__cd) $(top_builddir) && pwd` \
	  && $(am__cd) $(top_srcdir) \
	  && gtags -i $(GTAGS_ARGS) "$$here"
cscope: cscope.files
	test ! -s cscope.files \
	  || $(CSCOPE) -b -q $(AM_CSCOPEFLAGS) $(CSCOPEFLAGS) -i cscope.files $(CSCOPE_ARGS)
clean-cscope:
	-rm -f cscope.files
cscope.files: clean-cscope cscopelist
cscopelist: cscopelist-recursive
cscopelist-am: $(am__tagged_files)
	case "$(srcdir)" in \
	  [\\/]* | ?:[\\/]*) sdir="$(srcdir)" ;; \
	  *) sdir=$(subdir)/$(srcdir) ;; \
	esac; \
	  if test -f "$$i"; then \
	    echo "$(subdir)/$$i"; \
	  else \
	    echo "$$sdir/$$i"; \
	  fi; \
	done >> $(top_builddir)/cscope.files
distclean-tags:
	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
	-rm -f cscope.out cscope.in.out cscope.po.out cscope.files
distdir: $(DISTFILES)
	test -d "$(distdir)" || mkdir "$(distdir)"
	@srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
	list='$(DISTFILES)'; \
	  dist_files=`for file in $$list; do echo $$file; done | \
	  sed -e "s|^$$srcdirstrip/||;t" \
	      -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t"`; \
	case $$dist_files in \
	  */*) $(MKDIR_P) `echo "$$dist_files" | \
			   sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \
			   sort -u` ;; \
	esac; \
	for file in $$dist_files; do \
	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
	  if test -d $$d/$$file; then \
	    dir=`echo "/$$file" | sed -e 's,/[^/]*$$,,'`; \
	    if test -d "$(distdir)/$$file"; then \
	      find "$(distdir)/$$file" -type d ! -perm -700 -exec chmod u+rwx {} \;; \
	    fi; \
	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
	      cp -fpR $(srcdir)/$$file "$(distdir)$$dir" || exit 1; \
	    fi; \
	    cp -fpR $$d/$$file "$(distdir)$$dir" || exit 1; \
	  else \
	    test -f "$(distdir)/$$file" \
	    || cp -p $$d/$$file "$(distdir)/$$file" \
	    || exit 1; \
	  fi; \
	done
	@list='$(DIST_SUBDIRS)'; for subdir in $$list; do \
	    $(am__make_dryrun) \
	      || test -d "$(distdir)/$$subdir" \
	      || $(MKDIR_P) "$(distdir)/$$subdir" \
	      || exit 1; \
	    dir1=$$subdir; dir2="$(distdir)/$$subdir"; \
	    $(am__relativize); \
	    new_distdir=$$reldir; \
	    dir1=$$subdir; dir2="$(top_distdir)"; \
	    new_top_distdir=$$reldir; \
	    echo " (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) top_distdir="$$new_top_distdir" distdir="$$new_distdir" \\"; \
	    echo "     am__remove_distdir=: am__skip_length_check=: am__skip_mode_fix=: distdir)"; \
	    ($(am__cd) $$subdir && \
	      $(MAKE) $(AM_MAKEFLAGS) \
	        top_distdir="$$new_top_distdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
		am__skip_mode_fix=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
	  top_distdir="$(top_distdir)" distdir="$(distdir)" \
	  dist-hook
	-test -n "$(am__skip_mode_fix)" \
	|| find "$(distdir)" -type d ! -perm -755 \
		-exec chmod u+rwx,go+rx {} \; -o \
	  ! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -400 -exec chmod a+r {} \; -o \
	  ! -type d ! -perm -444 -exec $(install_sh) -c -m a+r {} {} \; \
	|| chmod -R a+r "$(distdir)"
dist-gzip: distdir
	tardir=$(distdir) && $(am__tar) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).tar.gz
	$(am__post_remove_distdir)
dist-bzip2: distdir
	tardir=$(distdir) && $(am__tar) | BZIP2=$${BZIP2--9} bzip2 -c >$(distdir).tar.bz2
dist-lzip: distdir
	tardir=$(distdir) && $(am__tar) | lzip -c $${LZIP_OPT--9} >$(distdir).tar.lz
dist-xz: distdir
	tardir=$(distdir) && $(am__tar) | XZ_OPT=$${XZ_OPT--e} xz -c >$(distdir).tar.xz
dist-tarZ: distdir
	@echo WARNING: "Support for shar distribution archives is" \
	               "deprecated." >&2
	@echo WARNING: "It will be removed altogether in Automake 2.0" >&2
	tardir=$(distdir) && $(am__tar) | compress -c >$(distdir).tar.Z
dist-shar: distdir
	@echo WARNING: "Support for distribution archives compressed with" \
		       "legacy program 'compress' is deprecated." >&2
	shar $(distdir) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).shar.gz
dist-zip: distdir
	-rm -f $(distdir).zip
	zip -rq $(distdir).zip $(distdir)
dist dist-all:
	$(MAKE) $(AM_MAKEFLAGS) $(DIST_TARGETS) am__post_remove_distdir='@:'
# This target untars the dist file and tries a VPATH configuration.  Then
# it guarantees that the distribution is self-contained by making another
# tarfile.
distcheck: dist
	case '$(DIST_ARCHIVES)' in \
	*.tar.gz*) \
	  GZIP=$(GZIP_ENV) gzip -dc $(distdir).tar.gz | $(am__untar) ;;\
	*.tar.bz2*) \
	  bzip2 -dc $(distdir).tar.bz2 | $(am__untar) ;;\
	*.tar.lz*) \
	  lzip -dc $(distdir).tar.lz | $(am__untar) ;;\
	*.tar.xz*) \
	  xz -dc $(distdir).tar.xz | $(am__untar) ;;\
	*.tar.Z*) \
	  uncompress -c $(distdir).tar.Z | $(am__untar) ;;\
	*.shar.gz*) \
	  GZIP=$(GZIP_ENV) gzip -dc $(distdir).shar.gz | unshar ;;\
	*.zip*) \
	  unzip $(distdir).zip ;;\
	esac
	chmod -R a-w $(distdir)
	chmod u+w $(distdir)
	mkdir $(distdir)/_build $(distdir)/_inst
	chmod a-w $(distdir)
	test -d $(distdir)/_build || exit 0; \
	dc_install_base=`$(am__cd) $(distdir)/_inst && pwd | sed -e 's,^[^:\\/]:[\\/],/,'` \
	  && dc_destdir="$${TMPDIR-/tmp}/am-dc-$$$$/" \
	  && am__cwd=`pwd` \
	  && $(am__cd) $(distdir)/_build \
	  && ../configure \
	    $(AM_DISTCHECK_CONFIGURE_FLAGS) \
	    $(DISTCHECK_CONFIGURE_FLAGS) \
	    --srcdir=.. --prefix="$$dc_install_base" \
	  && $(MAKE) $(AM_MAKEFLAGS) \
	  && $(MAKE) $(AM_MAKEFLAGS) dvi \
	  && $(MAKE) $(AM_MAKEFLAGS) check \
	  && $(MAKE) $(AM_MAKEFLAGS) install \
	  && $(MAKE) $(AM_MAKEFLAGS) installcheck \
	  && $(MAKE) $(AM_MAKEFLAGS) uninstall \
	  && $(MAKE) $(AM_MAKEFLAGS) distuninstallcheck_dir="$$dc_install_base" \
	        distuninstallcheck \
	  && chmod -R a-w "$$dc_install_base" \
	       (cd ../.. && umask 077 && mkdir "$$dc_destdir") \
	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" install \
	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" uninstall \
	       && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" \
	            distuninstallcheck_dir="$$dc_destdir" distuninstallcheck; \
	      } || { rm -rf "$$dc_destdir"; exit 1; }) \
	  && rm -rf "$$dc_destdir" \
	  && $(MAKE) $(AM_MAKEFLAGS) dist \
	  && rm -rf $(DIST_ARCHIVES) \
	  && $(MAKE) $(AM_MAKEFLAGS) distcleancheck \
	  && cd "$$am__cwd" \
	  || exit 1
	@(echo "$(distdir) archives ready for distribution: "; \
	  list='$(DIST_ARCHIVES)'; for i in $$list; do echo $$i; done) | \
	  sed -e 1h -e 1s/./=/g -e 1p -e 1x -e '$$p' -e '$$x'
distuninstallcheck:
	@test -n '$(distuninstallcheck_dir)' || { \
	  echo 'ERROR: trying to run $@ with an empty' \
	       '$$(distuninstallcheck_dir)' >&2; \
	  exit 1; \
	$(am__cd) '$(distuninstallcheck_dir)' || { \
	  echo 'ERROR: cannot chdir into $(distuninstallcheck_dir)' >&2; \
	  exit 1; \
	test `$(am__distuninstallcheck_listfiles) | wc -l` -eq 0 \
	   || { echo "ERROR: files left after uninstall:" ; \
	        if test -n "$(DESTDIR)"; then \
	          echo "  (check DESTDIR support)"; \
	        fi ; \
	        $(distuninstallcheck_listfiles) ; \
	        exit 1; } >&2
distcleancheck: distclean
	@if test '$(srcdir)' = . ; then \
	  echo "ERROR: distcleancheck can only run from a VPATH build" ; \
	  exit 1 ; \
	fi
	@test `$(distcleancheck_listfiles) | wc -l` -eq 0 \
	  || { echo "ERROR: files left in build directory after distclean:" ; \
	       $(distcleancheck_listfiles) ; \
	       exit 1; } >&2
check-am: all-am
check: check-recursive
all-am: Makefile $(SCRIPTS) $(DATA)
installdirs: installdirs-recursive
installdirs-am:
	for dir in "$(DESTDIR)$(rtems_makedir)" "$(DESTDIR)$(rtems_make_Templatesdir)" "$(DESTDIR)$(rtems_make_customdir)"; do \
	  test -z "$$dir" || $(MKDIR_P) "$$dir"; \
	done
install: install-recursive
install-exec: install-exec-recursive
install-data: install-data-recursive
uninstall: uninstall-recursive
install-am: all-am
	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
installcheck: installcheck-recursive
install-strip:
	if test -z '$(STRIP)'; then \
	  $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
	    install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
	      install; \
	else \
	    "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'" install; \
	fi
mostlyclean-generic:
clean-generic:
distclean-generic:
	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
	-test . = "$(srcdir)" || test -z "$(CONFIG_CLEAN_VPATH_FILES)" || rm -f $(CONFIG_CLEAN_VPATH_FILES)
maintainer-clean-generic:
	@echo "This command is intended for maintainers to use"
	@echo "it deletes files that may require special tools to rebuild."
clean: clean-recursive
clean-am: clean-generic mostlyclean-am
distclean: distclean-recursive
	-rm -f $(am__CONFIG_DISTCLEAN_FILES)
	-rm -f Makefile
distclean-am: clean-am distclean-generic distclean-tags
dvi: dvi-recursive
dvi-am:
html: html-recursive
html-am:
info: info-recursive
info-am:
install-data-am: install-dist_rtems_makeDATA \
	install-dist_rtems_make_TemplatesDATA \
install-dvi: install-dvi-recursive
install-dvi-am:
install-exec-am:
install-html: install-html-recursive
install-html-am:
install-info: install-info-recursive
install-info-am:
install-man:
install-pdf: install-pdf-recursive
install-pdf-am:
install-ps: install-ps-recursive
install-ps-am:
installcheck-am:
maintainer-clean: maintainer-clean-recursive
	-rm -rf $(top_srcdir)/autom4te.cache
	-rm -f Makefile
maintainer-clean-am: distclean-am maintainer-clean-generic
mostlyclean: mostlyclean-recursive
mostlyclean-am: mostlyclean-generic
pdf: pdf-recursive
pdf-am:
ps: ps-recursive
ps-am:
uninstall-am: uninstall-dist_rtems_makeDATA \
	uninstall-dist_rtems_make_TemplatesDATA \
.MAKE: $(am__recursive_targets) install-am install-strip
.PHONY: $(am__recursive_targets) CTAGS GTAGS TAGS all all-am \
	am--refresh check check-am clean clean-cscope clean-generic \
	cscope cscopelist-am ctags ctags-am dist dist-all dist-bzip2 \
	dist-gzip dist-hook dist-lzip dist-shar dist-tarZ dist-xz \
	dist-zip distcheck distclean distclean-generic distclean-tags \
	distcleancheck distdir distuninstallcheck dvi dvi-am html \
	html-am info info-am install install-am install-data \
	install-data-am install-dist_rtems_makeDATA \
	install-dist_rtems_make_customDATA install-dvi install-dvi-am \
	install-exec install-exec-am install-html install-html-am \
	install-info install-info-am install-man install-pdf \
	install-pdf-am install-ps install-ps-am install-strip \
	installcheck installcheck-am installdirs installdirs-am \
	maintainer-clean maintainer-clean-generic mostlyclean \
	mostlyclean-generic pdf pdf-am ps ps-am tags tags-am uninstall \
	uninstall-am uninstall-dist_rtems_makeDATA \
dist-hook:
	@files=`(cd $(srcdir); find doc cpukit c testsuites tools \
	   -name configure.ac -print | sed 's,/configure.ac,,' | sort)`; \
	for i in $$files; do \
	  if test -f $(distdir)/$$i/configure.ac; then : ; \
	  else \
	    d=`dirname $(distdir)/$$i`; \
	    $(MKDIR_P) $$d;\
	    echo "cp -pR $(srcdir)/$$i $(distdir)/$$i"; \
	    cp -pR $(srcdir)/$$i $(distdir)/$$i; \
	  fi; \
	done
	rm -rf `find $(distdir) -name 'autom4te*'`
	rm -rf `find $(distdir) -name CVS`
	rm -f `find $(distdir) \( -name .cvsignore \
	  -o -name config.status \
	  -o -name config.log \)`
	rm -f `find $(distdir) \( -name '*.bak' \
	  -o -name 'changes' -o -name 'diff' -o -name 'tmp' -o -name 'log' \
	  -o -name '*~' -o -name '.*~' -o -name '.#*' \)`
	find $(distdir) -name '*.in' -print | while read a; do \
	  f=`echo $$a | sed 's,\.in$$,,'`; \
	  if test -f $$f; then echo "rm $$f"; rm $$f; fi; done
preinstall-recursive:
	@set fnord $(MAKEFLAGS); amf=$$2; \
	dot_seen=no; \
	    dot_seen=yes; \
	  else \
	  fi; \
	  (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) $$local_target) \
	   || case "$$amf" in *=*) exit 1;; *k*) fail=yes;; *) exit 1;; esac; \
	done; \
preinstall: preinstall-recursive
.PHONY: preinstall-recursive
preinstall-am: $(PREINSTALL_FILES)
preinstall: preinstall-am
.PHONY: preinstall preinstall-am
# Tell versions [3.59,3.63) of GNU make to not export all variables.
# Otherwise a system limit (for SysV at least) may be exceeded.
.NOEXPORT:
