how to make a memory region non-cacheable, linkcmds section addition not working..
Chan Kim
ckim at etri.re.kr
Wed Mar 2 05:18:28 UTC 2016
Hi, rtems users,
I am writing a test program(an application) where I make interrupt using looped-back GPIO pins and process the interrupt.
Just to see some debug information, I wanted to locate a variable in a non-cacheable address range and the method I try to use is make a 16MB(=2^24) aligned memory region in the linkcmds.base and make that region non-cacheable by changing the pgd(page global data) table.(it's sparc architecture and I can know the actual allocated address using the variable address).
I put a section in the linkcmds like below (see .dmablock section, which is the non-cacheable area).
SECTIONS
.bss :
__bss_start = ALIGN(0x8);
_bss_start = .;
bss_start = .;
*(.bss .bss* .gnu.linkonce.b*)
*(COMMON)
. = ALIGN (16);
end = .;
_end = ALIGN(0x8);
__end = ALIGN(0x8);
} > ram
. = ALIGN(0x1000000);
.dmablock : {
*(.dmablock)
} > ram
.stab . (NOLOAD) :
[ .stab ]
.stabstr . (NOLOAD) :
[ .stabstr ]
But when I objdump the exe file, I find the dmablock section is not aligned to 0x1000000.
(it starts from 0x60029630, I expected 0x61000000)
It looks like the ALIGN(0x1000000) is ignored. (the section is located right after bss)
Is it right method to locate the dmablock after bss? or how can I locate the dmablock after the stack?
I couldn't find the variable __stack in the rtems source code.
For reference, the beginning of the linkcmds.base file has a comment below.
* The memory map looks like this:
* +--------------------+ <- low memory
* | .text |
* | etext |
* | ctor list | the ctor and dtor lists are for
* | dtor list | C++ support
* | _endtext |
* | .data | initialized data goes here
* | _sdata |
* | _edata |
* | .bss |
* | __bss_start | start of bss, cleared by crt0
* | _end | start of heap, used by sbrk()
* | heap space |
* | _ENDHEAP |
* | stack space |
* | __stack | top of stack
* +--------------------+ <- high memory
Chan
