Segmentation fault while running ticker.exe on raspberrypi
Pratik Singhal
ps06756 at gmail.com
Sat Mar 5 17:00:48 UTC 2016
Hello, I have been trying to build rtems for raspberry pi and trying to run
ticker.exe which is a sample program, without success.
I have followed the steps for building rtems for sparc/sis as given in
Google summer of code quick start guide except replacing sparc/sis by
arm/raspberrypi wherever required.
RTEMS compiles successfully, but when I try to run ticker.exe on actual
raspberry Pi, I get segmentation fault without any output. When I try to
run ticker.exe using arm-rtems4.12-run , then I get no output and the
process exits.
I have configured and built the rtems source using the following commands
1) ./rtems/configure --target=arm-rtems4.12 --enable-rtemsbsp=raspberrypi
--enable-tests=samples --prefix=$HOME/install_arm
2) make RTEMS_BSP=raspberrypi
The output of file command on ticker.exe is
ticker.exe: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV),
statically linked, not stripped
Why is the segmentation fault coming and what can I do to resolve it ?
Although, I have been successfully able to test the program for sparc/sis
combination using sparc-rtems4.12-run.
Thanks,
Pratik Singhal
URL: <http://lists.rtems.org/pipermail/users/attachments/20160305/31b588af/attachment.html>
