Problem building master
Isaac Gutekunst isaac.gutekunst at vecna.com
Mon Mar 7 17:15:30 UTC 2016
I think I've found some git trouble going on, so I'll give that a shot.
I think I might have a strange hybrid of the 4.11 and 4.12 branch due to
a nasty rebase.
Isaac
On 03/07/2016 11:54 AM, Isaac Gutekunst wrote:
> ../rtems/configure --enable-rtemsbsp="stm32f7x" --enable-maintainer-mode
> --disable-tests  --enable-cxx  --target=arm-rtems4.12
> --prefix=$RTEMS/lib-rtems --disable-networking
> Since this is still our unreleased BSP, there could be some issues
> related to it. I'm just not sure what to look for.
> I built GCC last week I believe.
> Here is the --version output:
> arm-rtems4.12-gcc (GCC) 6.0.0 20160228 (RTEMS 4.12, RSB
> b537e5536459e207fc8e56a1df3774c1700606d5, Newlib 2.3.0.20160226)
> Isaac
> On 03/07/2016 11:32 AM, Joel Sherrill wrote:
>> This is odd. I just did a fresh update and rebuilt sparc/sis with POSIX
>> enabled.
>> I didn't have trouble.
>> The gcc+newlib version bumped last week but that shouldn't have had an
>> impact
>> yet and wouldn't have broken this. It added prototypes for a few pthread
>> routines
>> I am adding.
>> How did you configure exactly?
>> --joel
>> On Mon, Mar 7, 2016 at 9:24 AM, Isaac Gutekunst
>> <isaac.gutekunst at vecna.com <mailto:isaac.gutekunst at vecna.com>> wrote:
>>     Correcting my subject typo.
>>     On 03/07/2016 10:23 AM, Isaac Gutekunst wrote:
>>         Hi,
>>         I'm trying to build RTEMS master for ARM, and am getting the
>>         following
>>         compile error:
>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c: In
>>         function 'pipe_interruptible':
>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:76:34:
>>         error: 'Thread_queue_Control {aka struct <anonymous>}' has no
>> member
>>         named 'state'
>>              the_barrier->Barrier.Wait_queue.state |=
>>         STATES_INTERRUPTIBLE_BY_SIGNAL;
>> ../../../../../../rtems/c/src/../../cpukit/libfs/src/pipe/fifo.c:80:34:
>> member
>>         named 'state'
>>         I can't seem to find a definition for the Barrier_Control struct,
>>         andhaven't been able to find a root cause.
>>         It could as always be a bootstrapping/cleaning problem where the
>>         wrong
>>         file is being built, but I don't think so.
>>         Anyone know what's going on?
>>         Thanks,
>>         Isaac
>>         _______________________________________________
>>         users mailing list
>>         users at rtems.org <mailto:users at rtems.org>
>>         http://lists.rtems.org/mailman/listinfo/users
>>     users mailing list
> users mailing list
> users at rtems.org
